help with cam id
Results 1 to 14 of 17
help with cam id
    custom member raped southwind's Avatar
    so-cal
    Default help with cam id
    looks like maybe 328/336 on a 112 solid roller. but thats all i get
    Senior Member sammyc57's Avatar
    Sep 2010
    Broken Bow,OK
    Quote Originally Posted by raped southwind View Post
    you could call the grinder and ask. That's what I had to do with my bullet to get the timing events.
    so-cal
    only guy that had info on this cam has passed away.
    Sep 2010
    Broken Bow,OK
    as far as lobe lift, you can measure that with a good caliper, other than that Im no help maybe gn7, bp, steelcomp, or several others that actually could help will step in!hopefully youll find the info your lookin for.
    Those look like lobe numbers, probably based on adv. duration. I see "cc" which means it might be a Comp custom grind. I can look in the Comp catalog tomorrow. We have a Cam Doctor and can tell you exactly what it is if you don't get anywhere with the numbers.
    328-6 int lobe:
    High RPM INTAKE ROLLERS
    The High RPM Intake Rollers are used on highly modified, high rpm drag race motors . They are used primarily with ported heads that
    incorporate light weight valves and high spring loads
    [email protected]
    [email protected]
    [email protected]
    lobe= .456
    1.7 rocker= .775"
    336-5 ex lobe:
    High RPM EXHAUST ROLLERS
    These lobes are used on the exhaust side of highly modified, high rpm race engines . The cylinder head efficiency directly determines the design used
    [email protected]
    [email protected]
    [email protected]
    lobe= .440
    1.7 rocker= .748
    Not sure what the R12 stands for.
    Chantilly Va.
    R12 is an automotive air conditioning refrigerant. Replaced with R134, duh...
    so-cal
    328-6 int lobe:
    [email protected]
    [email protected]
    [email protected]
    lobe= .456
    1.7 rocker= .775"
    336-5 ex lobe:
    [email protected]
    [email protected]
    [email protected]
    lobe= .440
    1.7 rocker= .748
    Wow. Thank you. I spent the better part of 3hrs looking into this cam today. I greatly appreciate your help. Needless to say I will be needing a new cam.
    Sep 2010
    Broken Bow,OK
    ya see there, I told you that someone that knew more than me would chime in.lol
    Nov 2009
    Quote Originally Posted by sammyc57 View Post
    Are you impressed? That info is in Comp Cams catalog! Lol
    So the guy thanks Steel for supplying the info and this is the bullshit you come off with.
    And yet, it wasn't you that posted it. Go figure.
    But you are right, the info is in the Comp catalog, once you know it was a Comp Cam,
    Nov 2009
    LOOK DICK, I wasn't trying to pick a fight so chill, If that was the case I could do that and MUCH more....... I was only pointing out it was there I found that info in 2 sec...... I figured the OP already new that much! It's as easy as plugging in the numbers doesn't matter if you KNOW which Cam co........... Lol you are the pro reader....? Why didnt you post it?
    That was the first I saw of the thread. But I didn't need the need to stick my thumb in the eye of the person that supplied him the info. Its all he wanted and he said thanks. Can't beat that.
    By the way, was that a threat I read? It reads similar to a couple PM's I have from you.
    Nov 2009
    "hey Steel "works" for a " Cam guy" I wouldn't discount anything he says!"
