solder
Results 1 to 9 of 9
solder
    Apr 2010
    Rocklin, Calif.
    Default solder
    When building batt. cabels,what solder do you use for the ends?
    I use rosin core
    Apr 2010
    Rocklin, Calif.
    Cool
    Thank's
    I use rosin core
    Right,, never use acid core or soldering acid for electrical connections, it will corrode the wire.
    For battery cables, you may have better results if you buy a tin of solder paste that you can dip the copper into prior to applying heat. You will find the solder flows quite a bit better than just trying to heat and apply the solder to the bare copper.
    Senior Member buckjohnson's Avatar
    Aug 2009
    Biola CA
    Why don't you crimp?
    At work we have cool battery terminals with solder already in them.put them in a vice with small torch shootn at it and jus push the cable into it slowly.theyre awesome.lil heat shrink over that and its connected
    San Diego, CA
    X100
    Flux, crimp, solder, heat shrink.......
    Boat 405.
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Ya forgot to cross drill and bolt... The terminals with the solder in them are the cats ass for sure...
    Steve
    Lake Havasu az.
    Yep, stick the terminal in a vice, get a roll of thick rosin core, heat the terminal just enough to melt the solder, if the cable fits the terminal properly fill it about half way, stick the cable in ad add heat until the solder wicks up the cable..add heat shrink if you feel the need...it will probably last a lifetime...and no more wing nuts on batteries, replaced a 6a a while back on a buddies boat over a loose wing nut.
