Bearing Clearance? - Page 2
Page 2 of 2 FirstFirst 1 2
Results 15 to 28 of 28
Bearing Clearance?
  1. #15
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Small blocks used to come like that from GM, something about a semi-line bore.
    I saw a guy hone a little extra on the big end to get a little more clearance,probably not the right way but it hasn't caused any problems so far.
    If i remember correctly GM calls .001 minimum on rods....fine for a basic mo ho but in a boat it will start pitching parts after a few min. @ 5500. 2.199 crank and std brngs and the dummy who assembled it didn't double check machine shop.
    The line hone establishes the bearing "crush", not a good idea to jack with that.
    QE 439 Twin Turbo
    I can't say I ever saw GM do that with a SBC, but of the 2 BBCs I have stripped down that I KNOW were factory original, both hand mismatched bearings to account for misalignment. I have built a few SBC that were not align honed, and never built a BBC that wasn't.
    Honing bearings for clearance is nothing new. Vic Edelbrock use to use under sized main bearing and align hone the block with bearings installed pretty regularly. But the bearings had .015-..020 of silicon aluminum bearing material. You can hone a King bi metal bearing with no problem.
  4. #17
    [email protected]
    Ohio
    The engine is a N/A 468 single Dom. Has a Callies Compstar crank, Eagle H beam rods internally balanced and the mains have been align honed when converted to 4 bolt. The second machine shop I had it to, said it was done right. I'm running this in a 9 second hydro turning 7500. Sounds like you guys are leaning to the tighter clearance. What brand of bearing is suggested? Plain or coated? Thanks
    Tim
    Gone
    Sparks, Nevada
    As to not to high jack a thread, back in '09 I was having bearing issues. I was running .0025/.003 clearance turning 7500 RPM with an Eagle crank. I found that the crank was bent and replaced it with a Compstar. I was also told my clearances were to tight and I was told to use .003/.0035. They ended up at .0029/.0034. Now lately I've been reading and it seems my clearances are big and it's being recommended to use the tighter ones again. I've checked my bearings and feel I can reuse them and only replace the rings. Now I'm wondering about clearances again.
    Tim
    I don't get it.
    You had "bearing problems".
    You changed the crank and the clearance.
    Now you have checked your bearings and they look so good you can reuse them.......but you want to jack with that.
    Sounds like you need to stop reading so much.
  7. #19
    [email protected]
    Ohio
    I don't get it.
    Thats just what I was thinking. Seeing these clearances tighter got me thinking more than I needed. I guess I should have listened to Jockorace in the first place. Thanks
    Tim
  8. #20
    Whitewright, TX
    I don't get it.
    x2 ! Jocko
  9. #21
    I actually think you answered your own question! Jocko
    I don't remember anybody saying those numbers are too big. Maybe bigger than necessary, but they will work fine with the right oil.
    You don't mention what the "too tight" clearances were. Maybe they were, maybe they weren't.
    I don't get it.
    I think it was answered in post 2 & 3.
    I will the very first to admit, I don't remember ever using a half set to tighten clearances, looser yes, but never tighter. Many have, and I fully understand their reasons. I just have never found it necessary. I am admittedly more than willing to run a little looser than many.
  10. #22
    Gone
    Sparks, Nevada
    To that end Bob I have done that many times. Very common to get the clearance I know that works for me. I have even used Kings
    because they have more clearance in a situation where the line hone might be a little tight and the crank a little high.
    But the bottom line is if it ain't broke don't fix it.
  11. #23
    So what do you do if you only need to gain (or lose) .0002" or .0003"?
  12. #24
    New Port Richey, FL
    Mic it again until you don't.
    I think I saw Fiat on here.
    QE 439 Twin Turbo
  13. #25
    I have only had to lose a smidge once when it was just a too much even for me. So I coated the bearings because it made feel better. Seemed to work fine. I could have in that one situation used a half set and been a shade tighter. Never seen a crank that need a full undersized set, although I have heard of them. A member PM'd me about needing .002 under not too long ago.
    I would use an undersized half set it I had too, just never been there. If I was trying to reduce the clearance by .0003, I would have to be at something approaching .004 on main or .0035 on a rod and then I would be concerned that I removed .0005.
    I really lose very little sleep over bearing clearances.
  14. #26
    okie, lake Texoma
    So does is that a make it or break it deal? .0028-.0030? .0029-.0031? Mains-Rods-when does it make an engine blow all to hell? Quit beating around the bush and lets hear some dead positive specs to build buy. Blown, Nos, N/a, stock, 8cyl but only running on 6cyl. ect.
    H8-2-W8
    [email protected] first pass
  15. #27
    I myself can't answer that Hass, by in my personal use, it would have to be more along the lines of .0037 or .0038. Then I am ready pull it back to .0035. Its never entered my mind to "fix" your above numbers. But like I said, I lose very little sleep over bearing clearances.
  16. #28
    Its always helpful to a set of + and - mics on hand to get you where you want to be
    Yeah, who know Bob was lurker.
