Always one, with me
Results 1 to 14 of 17
Always one, with me
    Senior Member Deweydaddy's Avatar
    DBN./DBN HTGS. Michigan
    Default Always one, with me
    Fock.........On my back all day, pulling the tranny back to get to the flexplate bolts on my truck......one mother*&ker is rounded off....only have about 3" to get a 12 point wrench on.......Looks like going to have to get a cutoff wheel in there.....Pain in the azz.......you think it'll back out after cutting head off? I hope there is enough meat to grab it with vise grips or with whatever......
    Id rather live with a good question than a bad answer.
    okie, lake Texoma
    Quote Originally Posted by Deweydaddy View Post
    After you cut the head off & get the flywheel out of the way, put a nut on it and zap it in the middle of the nut with a mig welder, the get on the nut with a wrench & back it out. Don't forget to unplug ALL electronics, ECU and all before welding on the vehicle.
    H8-2-W8
    [email protected] first pass
    It will probably spin out by hand unless its rusted. If you do cut the head off, you still have the thickness of the trans case left of the bolt to grab with vise grips.
    If you can find a Sears store with this set in stock, and you can get in there, consider the bolt as good as out.
    They have the same thing in end wrenches. If there is any flat left on the bolt, these will grab it.
    Thanks guys.....I quit after I almost lost teeth.....Sucks, being on your back.....9/16" with 1 1/4" pipe persuader on it.....Keeps slipping off. Those wrenches look nice.....I have a old Williams 7/16" I love.....Its really narrow, and strong....I think that one bolt was spun.....
    If you have an air chisel and a long, flat blade bit, you can rattle the bolt head on the side in a counter clock wise direction. This will usually bust it loose and once it moves a little bit you can probably unscrew it by hand.
    Dec 2010
    Sapulpa ok
    Before I started cutting I would try one of these spline wrenches, they work good.
    Well......got it off .....I went to sears and bought a few things.....one item was the wrench set gn7 posted.....nice set....it'll replace a set I got from my dad...hand me down stuff...I was in denial...dads gone....and the tools were heavily used....I was too stubborn to replace them. They mean a lot to me....I got a real good bite on that rounded nut with the new set.....it ate the rest of the head off....I then pulled out the other tool purchased....it's a kit of 6-8 heavy grade low profile bolt extractors.....pounded it on to the head of the bad bolt....15/16 wrench on it.....busted it loose. New flexplate installed.....new bolts!!!! Installed new starter (summit brand), I bought new flexplate and starter......now dealing with starter crap.....it won't engage into the plate.....roll crank....it might.....next time it won't ......took off for the third time....put it on the bench....it chatters at times when I test it.....should of bought the better starter.....cheap focking shit....now I'm dealing with it....came in for a drink....go back out there tomorrow .....
ID:	470825 Click image for larger version.
    deckboat owner rschap1's Avatar
    Lowell MI
    Default Craftsman :)
    Congrats on the fix.
    I may have to look into a set of those wrenches and those extractors.
    I have a lot of EZ outs and have seen the type like you show, but never thought of buying any...
    until now.
    Quote Originally Posted by rschap1 View Post
    until now.
    I had my doubts.....wrenches will get used.....extractors not so sure....at 25 bucks.....worth it. Saved me from having to use a cut off wheel.....on my back....in my face...with tranny pulled back 4"....
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Hey, be glad you're in the garage and not out in the snow buddy .... me ... I don't have to worry bout no stinkin snow, it's all gone and extended forecast show'n nuttin but sunshine for next two weeks Alaska baby it's the place to be
    PS ... real sorry to hear bout your weather up there Dewey, sounds real cold to me
    well, after messing with the POS Summit Mini starter.....bought a Hitachi mini and all is well.....I also changed out the 750 DP Holley for a 650 DP.... Holley also.....was chasing a bog all last Summer....with the 750....throttle response now seems instant.....no test ride yet......I also now notice......at idle, carb is whistling....I've heard in the past.....that, that could be a indication of a " under sized carb " for the application ?????? 355 sbc, small hyd roller....zz4 basically with a cam up grade...510 - 525 @ 108 CL
    Tower Park Resort, Lodi, CA
    Listening through a short piece of hose while probing the other end around the carb can sometimes help identify it's source and location. My bet is it's a small vacuum leak between the manifold and the carb. Could be coming from somewhere else, but in my experience another re-torque after removing, inspecting, and re-cleaning surfaces can fix it and sometimes a new gasket takes care of it. Others may have had different experience, it's not something I've had an issue with recently.
    Thanks....can't hurt to look in that area.....the whistle tho is more (to me) like the carb is sucking at a high rate...I can hear it in the driver seat while tipping in the gas .....maybe the new carb is more efficient and that bog is history....hope to drive it soon.....still lots of snow here and cold....going to 48 today tho!!!!!!
    Whitewright, TX
    Dewey, you can actually hear a carb throat whistle WITH the air cleaner on? Or, you're hearing with it off ?? Jocko
