aluminum block ?'s
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 125
aluminum block ?'s
    sacramento
    Default aluminum block ?'s
    how durable are they if i was to pony up for one? could i run big hp for long time or are they high maintenance? do they flex too much? etc. -thanks
    okie, lake Texoma
    Quote Originally Posted by turbo wog View Post
    Mark is running a New century, and I am running a Brodix without any issues. Both of us have been at 30+ psi .
    H8-2-W8
    [email protected] first pass
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You don't want an aluminum BBC unless you are racing or the highest end of lake boating.
    QE 439 Twin Turbo
    okie, lake Texoma
    With aluminum blocks being very common in production vehicles today I have to ask why you say this?
    H8-2-W8
    sacramento
    yes, wondering why?......... i am against putting an extra 50-90 lbs in my boat form an iron block . i am trying to improve e.t.
    sacramento
    have you noticed a pump pressure loss on top end with less weight or ill handling in rough water due to light back end?
    sacramento
    are you running an alumn block too?
    okie, lake Texoma
    Yes, my engine has a Brodix aluminum block. And I have been very happy with it.
    H8-2-W8
    okie, lake Texoma
    Non of that BS
    H8-2-W8
    sacramento
    oops! that ? was for ron.
    sacramento
    Non of that BS
    good to know!
    sacramento
    are you running alumn too?
    You don't want an aluminum BBC unless you are racing or president or vice president of the IRF.
    Maybe he is considering a position on the IRF board of directors
    first I would suggest he fix the issues he already has without tackling an aluminum block.
    sacramento
    is that is directed towards me ? i am told that i should get a new block by my engine builder. #8 hole has been sleeved from a cylinder crack & started leaking after the repair. most likely from being a factory block bored .110 over pushing over 1100 (estimated)hp. lots of deck threads have been repaired from stripping out, water always in the oil, head not keeping flat,blown head gaskets,etc. . i read that the o-ring should be a figure 8 style instead of the way my block has been done (for alum heads).... a lot to think about . need to make a plan for next build/repair.
