how much vacum is to much?
Results 1 to 11 of 11
    Senior Member tx-19's Avatar
    wittmann,az
    Default how much vacum is to much?
    Looking to get rid of my aerospace vacum pump.it would only pull 8 at wide open throttle. Would a moroso enhanced 3 vane be okay or is the 4 vane better?
    Quote Originally Posted by tx-19 View Post
    For a wet sump deal 11-12" is about as far as you want to go without doing a lot of prep. The 3 vane Moroso will probably get you there. They do make rebuild kits for the Aerospace pumps.
    wittmann,az
    I did rebuild it and it didnt get any better.i have read that those really dont pull to much more
    I had one on the last 565 I did and it pulled 11.3 @ 7000 with their pulleys. I've heard the inside of the cases wear and not sure if a rebuild can fix that.
    Senior Member bp298's Avatar
    LHC
    engine condition, and how well it's sealed to prevent in-leakage, will also affect it...
    I heard the on Aero does move a lot of air compared to the Moroso. They seem to work ok small blocks and smaller BBC.
    The Moroso 3 vane moves more air than the 4 vane, but it can't pull as deep of a depression. The 4 vane moroso is designed to be aided by a dry sump and pull a deeper depression.
    None of them work to well if your engine is a leaker
    So how much more HP or other benefit do you think you'll get with another few inches vacuum? I wouldn't change it just for that. Now the Aerospace are more a drag race kinda deal and if it's a lake boat, you may want something that might have a bit more longevity. If that's the case, check out GZ Motorsports stuff.... Personally, I run the Aerospace stuff because it's billet and shiny which is generally good for a couple tenths at CFW (less so at the track)
    wittmann,az
    Motor is sealed up tight.not really looking for more horsepower, its a 585 cubic inch just want it to breath right.i was reading that the aerospace pump is to small for the cubic inch
    Senior Member Futs's Avatar
    Orange CA, Big River
    Motor is sealed up tight. not really looking for more horsepower, its a 585 cubic inch just want it to breath right. i was reading that the aerospace pump is to small for the cubic inch
    I would leave it alone. It's not like you really lean on the engine anyways.....more of a show piece that gets you to the sandbar and back....lol
    I got 10.9" on mine at 6200 I plan on doing a rebuild on it and hope it works the same this time around on the dyno. Mine was good for 35 hp with a standard ring pack. Going a little more low tension this time around.
    wittmann,az
    I wonder if I took the relief value out of the pump if it would pull a little more.
    Senior Member Bruise Brothers Dad's Avatar
    Pomona,Ca
    Don't beat me up over this, it's my car that I restored. Used this before and @3500 rpm it pulled a little over 7 inches of vacuum, 12 at wot. Surprised a lot of people with a stock replacement smog pump, real cheap but does the job. Even surprised a tech at the drag strip.
ID:	476274   Click image for larger version.
    Need help finding this 1973 Sanger 18'6" bubble deck mahogany bottom and stringers I was living in Pomona when I sold her in 1979. Just wonder if she still exists
    Update Found my old Sanger 12/7/14 in Reno.
