If you had a 502 what would you build?
Results 1 to 14 of 29
    Senior Member Notalent's Avatar
    Dallas/HB/LBC
    Default If you had a 502 what would you build?
    We just got a warranty claim in on a what was once Brand New GM crate 502. The guy spun a couple bearings and we sent him a new engine. I now have the engine and can build it to what I want....It was the zz502/502HP. One thing that will be added for sure is the new unreleased F.A.S.T EZ EFI system, I already spoke to them and they are donating it for us to test
    I was thinking of maybe just turning this into a 540 with a new Scat kit....re working and match porting the Edelbrock Performer RPM Heads with a Dart single plane, putting in a nice Solid Roller Cam etc...
    Im looking to get 650-700HP, STREETABLE I think the only downfall is the damn Electric Fuel Pump I will have to use..
    "Pain is a figment of your Imagination"
    Yeah those Damn electric pumps, can't even buy a new vehicle
    without one anymore, they must suck....
    #55
    Dallas/HB/LBC
    haha...I dont want one, I prefer mechanical....cheaper and easier to fix...not to mention not ELECTRIC!
    Senior Member The Violater's Avatar
    Quote Originally Posted by Notalent View Post
    The Dart single plane will probably make the most hp, but c'mon you gotsta have dual carbs on at least a cheap tunnel ram to make a total statement................... !!!!!!!!
    / The Few The Proud TheBlown
    Dallas/HB/LBC
    Quote Originally Posted by The Violater View Post
    Haha...I dont want nothing poppin outta the hood..
    Intersting thing I saw today while at work....I designed a nice 383 Stroker for a guy and he realllllly wanted a trip deuce setup....so I got him the Barry Grant tripple deuce...$2400 retail....and the biggest piece of shit intake manifold I have ever seen!!!!! What cheap shit...matched HIS gasket up to it....and holy fock was every port way off! No wonder so many companys are dropping him...sending it back with a big FOCK THIS sign on it! I will post pictures tomorrow.
    ,,,,,,,,,, Put that BAD DAWG in a 32 Ford or something............. hood problem solved!!!!
    I think you're on the right track. 540, (Scat is good) 10.5:1, set of nice heads (I might go a different direction there) single plane Dart or Edelbrock, and a 1050 (or in your case the EFI). Definitely a custom roller to get the most out of it and a good kickout pan if room permits. 700hp very doable, IMO.
    Electric fuel pump?
    Just run redundant blues and you will be fine....but keep a spare in the garage.
    Brian
    Dallas/HB/LBC
    I would rather keep the heads and be cost effective, cant be greedy when its free Im gonna give Moroso a call on monday for a donation...I should be able to fit a nice pan in the chevelle.
    FYI on a mild build many moon's ago:
    http://www.performanceboats.com//showthread.php?t=451
    Sleeper CP
    Big Inch Ford Lover
    Ada, Michigan
    The electric pump problems I've had in the past were all with Holley pumps.
    Since then I swore off all Holley products.
    I have never had problems with Aeromotive electric pumps.
    I have an Aeromotive street rod electric pump that I blocked the bypass off to make it produce 42 # of pressure to prime the EFI system. That's pretty abusive It only runs until the motor starts and then the cam driven Aeromotive pump takes over. It has worked fine for three years that way.
    cfm
    cfm is offline
    The ZZ502 heads are Oval Ports (coined Rovals ) 290cc intake runners and 110cc combustion chambers.
    Good luck getting that much hp (700hp) with them - even with some re-work I don't really see it being that possible.
    Be cheaper and more productive to sell them and get heads that will let you get close to your wanted power levels.
    Or go cheap and repair what's broke and make an upgrade or to to get 550-600hp.
    What are the thoughts from the guys in your engine shop ?
    The ZZ502 heads have lots of meat on them, they can be opened up a bunch. I've got a set that have been opened up, to rectangle large port all the way to the pockets, flowing 395/292 with a 4.25 sleeve on a Superflow bench. The velocities in the runners are excellent, can't wait till next season to run them. The CC on the chamber is more like 114 cc rather than the claimed 110 cc. On edit...My intake valve were upped to 2.3 dia, from 2.25, the exhaust valves are inconel 1.88 dia.
    okie, lake Texoma
    http://www.racepumps.com/
    Check this pump out, will put out 450gph and 150psi without the need for a return line,and great for efi.
    I'm running one of the carb versions which puts out 50psi and I love it. It has enough press. and volume to handle the carbs and also my 325 shot of NOS that I run most of the time.
    The pump will support 2500hp according to the manufacturer.
