HP guess on build
Results 1 to 14 of 15
HP guess on build
    Feb 2010
    Default HP guess on build
    A buddy of mine is putting this package together. He already has the long blocks.
    522CI
    Lunati double cut 4 inch stroke crank
    Oliver rods
    4.560 bore JE -28cc dish pistons
    7.75 Static
    242/248 .630ish lift 112LSA hyd roller cam
    Edelbrock marine 454R 315cc heads
    Littlefield 10-71
    Whipple moac intercoolers
    Nickerson 980 carbs.
    12lbs of boost.
    He would like to make 1000HP at 6000 on pump gas. What would you think this package should make?
    Nov 2009
    Well I am going out on a limb here... I think it will certainly make more power than a GN boat and FAR FAR less than a Big TT blow thru deal!
    Quote Originally Posted by Mild Thunder View Post
    522CI
    Oliver rods
    7.75 Static
    Littlefield 10-71
    12lbs of boost.
    Probably not with those heads and cam.
    Feb 2010
    Thats kinda what I was thinking. I been trying to talk him into a good set of heads, and cam, and forget about the boost number. He made over 1200hp with these longblocks with M4 prochargers and 16lbs of boost on the dyno. However, they didnt last in the boat. So now he is converting back to roots hoping to have a simpler, more reliable setup. Ive told him to forget about what they made with a procharger, because it wont make that with a roots. I think maybe with the right heads and cam he could hit his target. The flow numbers on those edelbrocks look awful, and the cam wouldnt be my pick for what he has there.
    Not only is the cam a little small side, but the Eddy heads don't have the best exhaust port in the business and the boat doesn't exactly have dry stacks or zoomies, the intake/exhaust split seems a little close.
    I find hard to believe they made that power with the Procharger. They are more efficient, but that only goes so far.
    Feb 2010
    With a cam swap, and lets say a set of brodix or AFR heads with CNC chamber option, how much power would you say is on the table over the Edelbrock and cam combo he has now?
    Senior Member Smallblocksperry's Avatar
    Jul 2011
    i've got some Dart Pro 1 345s assembled ready to run on .650"lift 1300$
    and a billet solid roller cast iron gear comp cam .252/[email protected] on a 114 .650"lift 150$
    Jun 2011
    Keep um straight steelcomp...........my thoughts exactly as soon as I read the stick specs and then 315cc's.........it's smothering...........
    Jun 2011
    MT.......just janking with ya......if GN7 or steelcomp give you advice a wise man will listen these guys do this stuff on a regular basis.........I've gotten right advice from them both at one time or more.............PD
    Quote Originally Posted by purpledragon View Post
    Ya. But that GN7 guy is a Ass.
    Thumbs up
    Quote Originally Posted by Smallblocksperry View Post
    Ran that same cam in my blown 475bbc with 320's and it ran awesome! With a pair of 750's idle'n rich it had a nice surge
    Close to the water...
    If your putting a package together
    Look at what Teague Marine does to run at the power levels you want !
    Screw blower, less heat, more eff. The biggest inter coolers
    A three stage raw water pump to keep things cool
    The GN -77 is the Teagues Parker Endurance race boat it sports a old school look Quad rotors w/ carbs simple and effective
    1400 hp on race gas
    Running pairs the EFI is real nice, I like the advantages and protection of integrated engine management that comes with the price tag
Name:	2012 parker 300 032.jpg
ID:	476506   Click image for larger version.
Name:	2012 parker 300 012.jpg
    Jun 2011
    I think maybe straight forward is how I seem to see him.......calls it like he sees it.....I have been accused of the same a time or two.......JMHO
    Senior Member Teague Custom Marine's Avatar
    Valencia, CA
    522CI
    Oliver rods
    7.75 Static
    Littlefield 10-71
    12lbs of boost.
    First off DO NOT run that much boost on a roots blower setup with 91 octane. I would say 9-10 lbs MAX even at under 8:1 compression. With a screw compressor you can run higher boost safely because of less heat generated. The gains are two-fold because a screw compressor also takes less horsepower to run....
    With those heads and cam with a roots you are looking at 825-850 HP at 5700-5800.
    With 355cc heads and a 632/632 256/264 cam and a screw compressor you could get 1000+ HP on pump gas.
    That being said the configuration you described is not a bad setup. Wouldnt be my choice of carbs we would put on some holley 750 double pumpers, but otherwise a good 800 something horsepower pump gas setup. Just dont expect 1000...
    John Teague
