Question about rods...
Results 1 to 8 of 8
    Senior Member jms-1's Avatar
    Feb 2009
    Alpine, ca
    Default Question about rods...
    So I'm still rounding up parts for a engine, money has been tight for a long time now so its been a slow process (one part at a time while I save up). Its for my 19' Miller jet not a race boat. I am building a pump gas 496. I already have a Callies crank, forged Mahle pistons , and now I need to get some Rods. I know they are something you don't want to skimp on but i don't have a huge budget ether. I was looking at the Scat '' pro comp'' I beam with arp 2000 bolts. I thing they will work fine now but what if i want to add a little spray down the road? If any it wouldn't be more that a 200 shot. Or should i just hold out and get the Scat H beams with the bolt upgrade? Anything past that starts getting out of my budget. let the arguing begin....
    Quote Originally Posted by jms-1 View Post
    Nothing wrong with that rod at all.
    Feb 2009
    Alpine, ca
    Thank you Scott. Just so I have an idea, how much abuse will those rods take or at what point would you use the H beam with better bolts instead ?
    Hate to say without imperical data. I know guys are running the snot out of them in small blocks. 8000rpm circle track stuff. Big block I wouldn't push that kind of rpm but I think you'd be safe up to 7000.
    Callie's or the compstar line are great pcs also. Oliver is top of the top dog in high hp steel rods.
    The Scat Procomp I beam is a great rod for the money. But that's a hell of lot o crank for that rod. Kind of surprised you "saved" for a Callies crank, but now buying Scat I beam rods. Not condemning your choice of rods, just wondering why you choose this combo over a Scat 4340 crank and H beam rods, which would probably been cheaper.
    Was this a used Callies you got a killer price on?
    Feb 2009
    Alpine, ca
    I will admit it is overkill for what im building but I found it new for less than $100 more than the Scat. I also figured pistons and rods have a shorter life than a crank as long as it doesnt get hurt, and the crank will get put in somthing else down the road.
    That's cool, I would have bought it for 100 more too, NEW, used cranks are worth slightly more than used Kleenex
    I don't know if rods have a shorter life than the crank, if the crank is a Sonny Bryant and the rods are Olivers. But they sure as hell will if you use C.A.T. I beams and Silvolite cast pistons.
    But if cast piston fails a little earlier than you thought, hope the crank turns out to be near bullet proof
