Loosing rpm on big end
Results 1 to 8 of 8
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default Loosing rpm on big end
    So as stated I'm loosing rpm and power on the big end intermitiinly. If I'm in it all of a sudden ill feel a loose of power for a second or two and then it comes back to life. It's not dieing but just loosing enough to feel. Any ideas? This is a 500 inch ford with a dominator turning 6300 rpm
    Senior Member andyc's Avatar
    Feb 2010
    Valley of the Winds
    Default ignition.
    Possible ignition box-rev limiter pre-failure????
    okie, lake Texoma
    Fuel system, check/change filters, confirm wfo fuel pressure at the carb, make sure the pickup in the tank is in tact.
    Plug wires, check out the distributor cap
    H8-2-W8
    [email protected] first pass
    Mar 2010
    Clarksville, TN
    I had a kill switch breaking down that caused that. Took me forever to find it
    Thanks guys I'm guna look into all these
    Put a fuel pressure gauge where you can see it at wide open.
    It could be any of several things, but inadequate fuel pressure will do exactly what your talking about.
    Senior Member Flat Hall'N PS929's Avatar
    Torrance, CA / Big River, CA
    Is this a new set up? Sounds more like a fueling issue than ignition. Try what Jimsplace said, you may need a little more pressure.
    sacramento
    has it ran before correctly with this tune to confirm it is a failure of some sort? electric fuel pump getting weak,, too lean of any sort, (detonating from lean) , not enough octane or too much timing?plug fouling,wire misfiring ?
