pump gas n 20 ?
Page 1 of 54 1 2 3 4 11 51 ... LastLast
Results 1 to 14 of 751
pump gas n 20 ?
    Senior Member BOYWONDER's Avatar
    Default pump gas n 20 ?
    Have a few questions for the exsperts. Building a lake boat Cole runner bottom. Finally made my decision on route to go. Manifold is dart with induction solutions 2 stage setup (port) . Building motor around that system . What cubes ,rotating assembly ect. Was going to go a different route (blown e85) but want a pump gas deal that I can run around and then when I want to haul ass spray it down.... just looking for advice. Don't have any parts yet other than manifold, dry sump pan and system. Thnks.
    Quote Originally Posted by BOYWONDER View Post
    Who knows their system better that Steve Johnson? I sure he can tell you just how much compression you can get away for a given HP level.
    As far as cubes, its hard to beat 632ci based on a Dart 10.4" tall deck. Well, 700 ci based on a alum Donovan maybe.
    I know right Steve said 10.1 and spray with race gas. Cubes is personal preference he liked 540 I was thinkin 496. Anyway I'm starting from scratch. ...
    496 you can build from any MKIV 4 bolt. The 540 will require a 502 block at the least, or an aftermarket block.
    You still haven't mention the HP of the spray. 600HP 496 and 500HP of spray will probably not last to long with a stock block.
    You have to make those decisions, or somebody here will spend your money on billet cranks and Oliver rods, 14* heads and anything else they can dream up.
    Did you have a rich aunt that died, or are you doing this on aluminum can recycling budget?
    Left up to some of us here, we can spend your money like a drunken sailor on shore leave with a stolen credit card.
    Spray is 200hp or 400hp I guess I was lookin for what other people are using with success in lake boat application
    Sent from my SM-N900P using Tapatalk
    Derby, Kansas
    10.2:1 bbc 489 with AFR aluminum heads and mild roller. Runs 36* timining on our local 91 octane pump. Pushes my Hondo into the low 100s pretty easily, na only. What class do you want to run? A well built pump gas 496 will run ME in a decent flat and spray should let you go TE.
    Ada, Michigan
    . Was going to go a different route (blown e85) but want a pump gas deal that I can run around and then when I want to haul ass spray it down.... just looking for advice. .
    The blown E85 route would be a better way to go IMO if E85 is easily available in your area.
    Nitrous is the time payment plan power adder. After a few years you would have spent enough getting bottles refilled to get some real performance parts rather than "air"
    Calculate how many tanks of nitrous add up to what you would have into the blown E85 setup and the residual value of both systems.
    Interesting. E85 is readily available around here. Very inconsistent though as far as being true e85. This boat is gonna spend most it's life away from shore so some mileage kind of comes into play. I know it's a hot rod but don't want to be a shore dweller. I have a limited amount of time to finish project have another child coming so have to get going. Thnks for all the advice it's really helpful...
    If the Dart is un-ported I'd do 540ci.
    Unless you're willing to risk turning your expensive engine into a pile of trash, I'd stay away form pump e85. JMO.
    10-4. I have talked to you before . I have notes from that convo. You stated that then. Only reason I was gonna go toward 496 is I have access to a good block and crank.but the 540 makes more sense for future tear down/adding hp ect.
    SDBA #819 vdrivegrimes's Avatar
    Oct 2011
    100mph lake boat is very respectable
    Quote Originally Posted by Carnivalride:2961226
    Quote Originally Posted by B. OYWONDER View Post
    Derby, Kansas
    Quote Originally Posted by vdrivegrimes View Post
    Thanks it supposed to be competitive in the ME class but that has yet to be proven.
    I agree. Wasn't concerned about mph just want to accelerate realy hard hence the squeeze
