blower engine build ?
Results 1 to 7 of 7
    Senior Member Scapegoat's Avatar
    SoCal
    Default blower engine build ?
    If you were building a pump gas blower engine for a lake boat with 6lbs boost expected
    B&M mega 420, lee chiller, dual 850 holley boost ref.
    MK IV 454 block bored .40 over.
    2 bolt now, convert to 4 bolt.?
    rods I beam or H beam?
    aluminum heads. brand and size?
    pistons?
    Compression goals? etc.
    semi budget....
    What would you build
    Senior Member TexasJet's Avatar
    College Station, Texas
    You were doing so well till you said "semi budget".
    SoCal
    Right, kinda an oxymoron. Lol
    It would help a lot if we knew your budget. If it's $5000 the parts would be different than if it's $15000. Give us a starting point. As an example, I'm building a blown 540, probably gonna cost in excess of $18000 and I have some of the parts already. TJ
    Right off the bat, the .040 bore screams BUDGET!!
    Who makes .040 pistons that aren't budget pistons. Icon and Speed pro? Anybody else?
    Feb 2010
    Quote Originally Posted by Scapegoat View Post
    pistons?
    semi budget....
    I would go 4 bolt mains, with studs. IMO you have a potential 750-850HP combo with the right parts on pump gas. 2 bolt mains isnt what i would want there.
    I would go H Beam. (An H beam really doesnt cost much more than an i beam)
    I would go with a quality blower piston with upgraded pins.
    I have a pair of 468ci, with B&M 420's, 6lbs of boost, that made 804HP at 6200 on pump gas. They have been in my boat for 2 summers running great in this form.
    Mine are
    MARK IV blocks
    4 bolt mains with ARP stud kit
    GM 4'' steel crank
    Manley H beam rods with ARP 2000 bolts
    JE flat top blower pistons
    older Dart 308 Race series alum heads with some port work
    236/245 .630 lift, 114LSA Hyd Rollers
    Morel 4603 lifters
    Isky springs.
    Twin 850 Holleys.
    B&M 420's non intercooled
    MSD distributor with Crane ignition box. Timing locked at 32.
    SoCal
    Quote Originally Posted by Mild Thunder View Post
    Mine are
    MARK IV blocks
    GM 4'' steel crank
    Morel 4603 lifters
    Isky springs.
    Twin 850 Holleys.
    Cool thanks
