788 HP out of a 454 ???
Results 1 to 14 of 32
    Member Bahnerman's Avatar
    Yuba city
    Default 788 HP out of a 454 ???
    A friend of mine has a motor for sale, a 454 that puts out 788 dynoed hp. Heres my question I asked him what it had and what he told me just didnt make sense. Can this happen.
    19?? 454 block, stock crank polished, hyper 10-1 comp pistons, gm bowtie heads rectangular port with angle job and bigger valves. Dont know angle and size of valves. No head work. Pretty much stock head. Crane cam, dont know spec. but he said its mild. Single plane intake. Single 850cfm carb that was jetted. Ohh yea the blocks been preped
    He told me it has 1 pass on the dyno and thats it and it made 788 hp. The reason I ask is my buddy hydroman916 has a well fully built 454 that puts out 654hp on the dyno. Hydros engine builder says its possible. Hydroman says only one way to find out, to take it dynoed. cost $$$
    Can anyone shed some light... I know theres some guesstimating because of unknown of heads and cam. By the way he wants 1900 and has 6k into it.
    tell your friend that desktop dyno will let you make more than 1 pull per session i'm calling bs on 788, it takes some compression or a badass trick head/cam combo to do that.
    Yuba city
    I thought the same thing
    B.O.A.T - Beak Out Another Thousand
    Anything is for Sale for the Right Price !!!
    Morgan Hill
    I guess you would have to look at this a couple of ways, it could potentially make those numbers but IMO at about 6000 RPM + and that would basically state "mild camshaft my ass".
    The other way to look at it is he's asking $1900 for it and even if it made 300 HP, would be good deal.....
    I am having a hard time with the 788 ponies though.
    Use HP = Torque X RPM / 5252 as the formula, figure for approx 600-700 ft/lbs.
    GT
    GT
    Yuba city
    And speaking of rpms. 6800rs
    Morgan Hill
    Quote Originally Posted by Bahnerman View Post
    See what I mean? Does not compute....
    GT
    GT
    With what you're describing, it's MOST unlikely it's making that HP, and it would be at a lot higher than 6000rpm if it was.
    Morgan Hill
    Agreed, you would be way better off buying my 350 inch small chevy, cast crank and pistons, at $1800 and 750 HP much better deal
    GT
    GT
    Yuba city
    Im going to see him tomarrow and ask if he has any paperwork on it
    Newton Ks.
    Yea, it's very likely to be a high-rev motor, IF it makes that HP (I do think it's unlikely too), at whatever power it does make.
    H.L. Mencken
    East Side
    How much nitrous?
    Quote Originally Posted by Some Kind Of Monster View Post
    How much nitrous?
    300hp shot most likely
    As a matter of perspective:
    I know of a certain 565" Ford with a shit load of bad ass parts with 11.8:1 compression, a stout roller cam, heads that flow 450 cfm's, T&D 1.8 shaft rockers, etc, etc........ it made 935 Hp.
    935/565= 1.65 hp cu/in.
    There's a post over on the jet boat thread with an engine that made 1,040 hp I don't know if it's a 588" or a 632" but if it's a 632 that would be 1.65 hp/cu/in. If it's a 588" that would be 1.77 hp/cu.in.
    In 1994 I was at the Popular Hot Rodding Engine Master's competition where Jon Kaase's 410" Ford belted out 701 HP at 6,500. That was/is one of the baddest ass single carb pump gas engine's ever built, with enough trick parts to fill a written page and before Kaase took it to the competition he had 75 dyno pulls on it. That 410" engine made 1.71 hp/cu.in.
    The engine in question: 788/454= 1.74 hp per cu. in.
    In all due respect your friend or the dyno operator is Full of Shit !!!!!!!!
    Or that thing had nitrous on it.
    It would be nice to know the cam specs and head flow #'s before I make a judgement ? (Roller ? @ 6,800 rpms )
    Edit: Oh, one more thing; since this is a Big Block you're talking about here's a good read:
    http://www.popularhotrodding.com/eve...003/index.html
    My friend Dan Crower built a 470" BBC that I helped on ($) it made 720 hp on the Crower dyno at 6,500( FYI: it was in no way near "stock" not even close, including bad-ass Brodix heads with 99cc chambers and 11.25:1 compression).
    We think it would have finished in the top 4 of that year's competition. When we took it to Westec for dynoing it filled the dyno room with smoke from a push rod rubbing a hole in a intake port and sucked oil into the intake track.
    Sleeper CP
    Big Inch Ford Lover
    Senior Member hotbo's Avatar
    lake Ouachita AR
    no one mentioned that maybe the guy or the dyno was on crack
    lol!!that has to be the badest near stock bbc ive ever seen,but ive heard and seen weirder shiteither way for the money may not be a bad buy,hope it works out for ya,travis
