Tall Truck Block 496/ 510 worth the effort?
Results 1 to 5 of 5
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    Default Tall Truck Block 496/ 510 worth the effort?
    Just added a Tall deck 427 truck block to my core pile. So is it worth the trouble to do all the clearance grinding to fit a 4.25 4340 forged crank and H beams to get a longer rod and better piston ring and pin package? This build would be for 650hp no spray pump gas for my Sanger Mini v-drive R/C. Lots of long sustained 4000 rpm cruising. I was just going to build one of my standard 9.8 blocks, but this came along and I'm opening Pandora's box...
    Remember that the Ark was built by amateurs and the Titanic was built by professionals.
    Quote Originally Posted by Speed of Heat View Post
    Does your block already have any notches in it? Some of the later ones did, and may clear with little or no work at all.
    I still have to tear it down and check it out. Are the oil passages close and easily breeched? Water Jackets?
    With a 4.25 stroke you don't need to worry about the oil gallery down the side. If the block is notched at the bottom of the bores already, you only need to do minimal notching depending on the rods. If its early block and not notched, just take your time notching for the bolt head, don't make it too wide or too deep and you'll be fine.
    Most of the pre notched blocks are pretty close with most H beam rods. if you have to do a un-notched block, you won't be making notches this wide. A little more than a 1/4" wider than the bolt head.
    Senior Member jdl25_1998's Avatar
    Nov 2009
    Hugo-Bennington,Oklahoma
    How many tall deck blocks do you have ?
