Splayed Cap Conversion-BBC
Results 1 to 6 of 6
    Gone in a Flash! Speed of Heat's Avatar
    Lake Pend Oreille, Idaho
    Default Splayed Cap Conversion-BBC
    So, is a splayed cap conversion a good or bad idea? I know that the standard four bolt deal with straight vertical bolts is generally not thought of being terribly strong, but what about the splayed type? GM, Milidon, Eagle, Scat or who? Pros/Cons? -Help??????
    Tri-Cities, TN
    In the case of a BBC the staight cap is fine. Most aftermarke blocks in BBC config are straight and capable of handling big HP requirements.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Swollen Member SinisterGrin's Avatar
    I used the milodon kit on a two bolt to four bolt coversion 650 hp application, never had any problems with them, if you're using stock caps you can only use certain stock caps, some don't have enough material for the outside bolts and you'll have to buy after markets.
    Might as well just find a four bolt.
    Brendella 2" Runner NoS Arneson's Avatar
    Livermore & Copperopolis
    Yes, the HPrating on the straight cap 4 bolt is pretty hefty for most. The Milodon splayed 4-bolt coversion is a very $ machining process, but probably good if you are needing to run big HP/Torque blown, high piston speeds, etc. But in the 700 hp range, straight is certainly capable.
    - Gary "Mr Scary" Arneson
    1978 Brendella 2" Runner 463 Nitrous BBC
    MI
    I kept the stock 4 bolt caps and went with a main stud girdle.
    Quote Originally Posted by Arneson View Post
    Agreed. I priced it out and am going with a Dart block.
