Few bbc questions
Results 1 to 14 of 31
Few bbc questions
    Senior Member schiada flatty's Avatar
    Lloydminster Canada
    Default Few bbc questions
    Just took apart my 427 too find out if I had a head gasket leak and sure enough I did. But that's not all I found. Time for new pistons a bore and rebuild haha. The mains and rod bearings were blue hot. Cranks still standard and it had standard bearings. What kind of clearances would be ideal for a lake boat. I ran 15/40 syn and I got a 10 quart pan no cooler 70psi of oil press and usually 220F of oil temp after a couple good passes. Also what can you tell me about my cam? It looks like a custom grind.
ID:	494089Click image for larger version.
    At $100/ hp plus injection oil it's just to expensive to go that slow!
    Lloydminster Canada
    Heres some more
ID:	494105   Click image for larger version.
ID:	494113   Click image for larger version.
    Looks like it got into detonation. Most likely what took out the head gasket and the piston.
    Cam is 635 lift 262 @ 050, more than likely ground on 114 lsa. with an iron distributor gear.
    Lloydminster Canada
    I think she was a little high on comp for 91 octane. I was told its around 10-1. When I buy new pistons ill make sure it's pump gas friendly. I noticed it did like the timing a bit retarded like 6* base and the stiffer spring in the destribitor. Pistons were TRW L2239N and heads are 990s
    As for the cam would you keep running this one or switch it? Seemed to really pull hard around 4-6500 rpm. I didn't sounds as lopy as my brothers 285 Hyd roller. I don't wanna take away perf with two big of cam.
    Quote Originally Posted by schiada flatty View Post
    Depends on the heads what the compression was. 10 to 1 is doable with aluminum heads. More 9 to 1 with iron.
    Cam depends on the rest of the build, like heads. If the cam is ground on 114 LSA it will idle a little smoother than a similar cam ground on a tighter angle.
    Lloydminster Canada
    Pistons were TRW L2239N and the heads are 990s. I think that's closer to 10-7 or 11-1.
    Closer to 11.5.
    Maybe 11 to 1 if it had a composite head gasket. Way passed pump gas compression with an iron head
    Lloydminster Canada
    Closer to 11.5.
    what would you think I was making HP wise before? And would there be much of a drop in power with 9-1 comp hollow dome pistons which will lighten up the rotating assem which getting balanced again. Would my cam be too big for 9-1 comp?
    okie, lake Texoma
    Those bearings look stained like that when new. Just a piston & head gasket it appears.
    H8-2-W8
    [email protected] first pass
    Lloydminster Canada
    Bearings are clevette 77's. my cylinders are scratched enough to feel with the finger nail. So it's off to the engine shop to get hot tanked and bored 30 over
    Lake Havasu az.
    Isn't L2239N closed chamber? 990's open chamber 116-118 cc.?
    You must have crappy gas in Canada, I run those same (heavy) pistons with 109 cc iron heads and a .020 head gasket on 91 pump 38* locked and have never had a detonation problem.(your results may vary)
    The 77's in mine aren't blue, is that a car (spec)motor with a stock oil pump making 70 psi?
    Mine is .025 rods .032 mains with a mellings hv and 20/50 val.With 220* oil...maybe 70 psi...solid [email protected] 6800
    WHAT? You didn't know that GM assembled thousands of BBC with CC pistons and OC heads.? Specially crate engines.
    Lloydminster Canada
    Yup those pistons are closed chamber design ive been told and Were run with open chamber heads. The block is a 286 casting 4 bolt with a melling HV pump. Here's the clearances from the build sheet. Rods .002-00225 mains #1 -.002 #5-.0025 Pistons were .004-008 and ring end gap .018 As for fuel I'm not sure lol
    Lake Havasu az.
    And how do you get 11.0-1 compression with pistons that are 11.0-1 with closed chamber heads and he has open chamber?
    Kinda tight on the bearings, .0025 is the usually accepted number for rods and .003-0035 on the mains with a straight line bore.....Not so sure on the fuel? That's an opps, even at 10.0-1 91 octane be about the minimum although for some reason i get away with close to 11.5-1 and 91.
