? for GM techs.
Results 1 to 14 of 19
? for GM techs.
    Default ? for GM techs.
    Hey guys , need a bit of help. I just pulled the GM Shortstar motor out of my baja bug. I'm going to install new bearings and seals in it. The problem is, I can't find any info on this motor at all. I've looked all over the internet sites, and no luck. I'm looking for rod and main clearances, and torque specs. Any help would be appreciated. I'm hoping to have it buttoned up by next weekend, so I can get it back in the car.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Senior Member shan's Avatar
    Yuma
    Quote Originally Posted by DMOORE View Post
    Darrell.
    By shortstar do you mean the V-6? Or is it a 4.0L or 4.6L V8?
    El Cajon , Ca
    I would try asking a local engine builder! I know a couple in san diego if you need some phone numbers!
    Quote Originally Posted by shan View Post
    Yea, the 3.5ltr V6. Simply can't find any info at all. Like Marcsrollin said, I might have to call a shop. Maybe on Monday, if I can't get any info, I'll call turnkey engines. I know they used to build them, when they were still in production.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Darrell.
    shortstar, lol, never herd em called that. they put the 3.5l in olds intrigues as well between 99-02, you could look up specs for that, there's no variation i've ever herd of in the older 3.5liters. the newer 3.4 and 3.5 liters are based on the gm 3.1liter they've put in a shitload of cars since early 90's. if the 3.5 liter you have has the same look as the northstar cadillac motor, then i;m pretty sure the olds intrigue specs are right. check into it anyways.
    Yuma
    I can't get to it from home, but if you can wait until Monday I can access the manuals from work.
    if your a gm tech, you know you login and password to dealer world. dealer world can be accessed anytime, not just from work just go to gm dealer world, put in your info
    here's the specs and tightening info on the lil 3.5l you may have, this is the specs for the 02 intrigue 3.5l that looks like a mini northstar motor.
    2002 Oldsmobile Intrigue | Intrigue (VIN W) Service Manual | Engine | Engine Mechanical - 3.5L | Specifications | Document ID: 243684
    Engine Mechanical Specifications
    Application
    Specification
    Metric
    English
    General
    Engine Type
    V-6
    Displacement
    3.5 Liter
    212 cu in
    RPO
    LX5
    VIN ID
    H
    Bore
    89.5 mm @ 39 mm from deck surface
    3.523 in @ 1.56 in from deck surface
    Stroke
    92 mm
    3.622 in
    Compression Ratio
    9.3:1
    Compression Pressure at Cranking Speed (Throttle Open)
    965-1172 kPa
    140-170 psi
    Power
    160 kW @ 5600 RPM
    215 hp @ 5600 RPM
    Torque
    317 Nm @ 4400 RPM
    234 lb ft @ 4400 RPM
    Redline
    6500 RPM
    Fuel Shutoff
    6700 RPM
    Firing Order
    1-2-3-4-5-6
    Balance Shaft
    Bearing Clearance
    0.015-0.077 mm
    0.0006-0.0030 in
    Bearing Journal Diameter
    50.787-50.813 mm
    1.9995-2.0005 in
    Bearing Diameter
    50.838-50.864 mm
    2.001-2.0025 in
    Thrust Plate to Balance Shaft Clearance
    0.068-0.170 mm
    0.0027-0.0067 in
    Camshaft
    Material
    Cast Ductile Iron with Hardened Lobes
    Number of Bearings
    4
    26.948-26.972 mm
    1.061-1.062 in
    Bearing Bore Diameter (In Head)
    27.013-27.033 mm
    1.0635-1.0642 in
    Bearing Clearance
    New Limits
    0.041-0.085 mm
    0.0016-0.0033 in
    Worn Limits (Not Over)
    0.085 mm
    0.003 in
    Thrust Bearing Clearance to Number 1 Camshaft Cap
    0.05-0.29 mm
    0.002-0.011 in
    Out-of-Round (Not Over)
    0.007 mm
    0.0002 in
    Camshaft Runout from Center Journals to End Journals (Not Over)
    0.05 mm
    0.002 in
    Valve Timing
    Intake Centerline
    112 degrees ATDC
    Exhaust Centerline
    104 degrees BTDC
    Valve Lift
    Intake
    10.5 mm
    0.413 in
    Exhaust
    10.0 mm
    0.394 in
    Camshaft Drive
    Primary Drive Type
    Endless Chain
    Adjustment
    Hydraulic Pressure (Automatic)
    Pitch
    8 mm
    0.315 in
    Width
    12.3 mm
    0.484 in
    Secondary Drive Type
    Endless Chain
    Adjustment
    Pitch
    8 mm
    0.315 in
    Width
    12.3 mm
    0.484 in
    Connecting Rods
    Connecting Rod Material
    Forged Powdered Metal
    Bearing Material
    Aluminum
    Clearance Between Bearing and Crankshaft
    New Limits
    0.025-0.057 mm
    0.0009-0.002 in
    0.065 mm
    0.0025 in
    Lower End Diameter without Bearing
    59.134-59.154 mm
    2.328-2.329 in
    Piston Pin Bore Diameter without Bushing
    23.453-23.493 mm
    0.923-0.925 in
    Center to Center Length
    153.4 mm
    6.039 in
    Side Clearance on Crankshaft
    0.11-0.33 mm
    0.004-0.013 in
    Crankshaft and Crankshaft Bearings
    Crankshaft Material
    Cast Ductile Iron with Undercut and Rolled Fillets
    Main Bearing Clearance Limit -- New Limit
    0.017-0.047 mm
    0.0006-0.0018 in
    Main Bearing Clearance Limit -- Worn Limit
    0.055 mm
    0.0021 in
    Main Bearing Journal Diameter
    69.994-70.006 mm
    2.755-2.756 in
    Main Bearing Journal Out-of-Round (Not Over)
    0.004 mm
    0.00016 in
    Main Bearing Journal Taper
    0.004 mm
    0.00015 in
    Main Bearing Journal Length -- No. 1
    23.75 mm
    0.9350 in
    Main Bearing Journal Length -- No. 2
    24.00 mm
    0.9449 in
    Main Bearing Journal Length -- No. 3
    25.50 mm
    1.0039 in
    Main Bearing Journal Length -- No. 4
    24.00 mm
    0.9449 in
    Crankpin Journal Diameter
    55.448-55.462 mm
    2.1829-2.1835 in
    Maximum Crankpin Journal Out-of-Round
    0.004 mm
    0.00016 in
    Maximum Crankpin Journal Taper
    0.004 mm
    0.00016 in
    End Play in Crankshaft -- New Limits
    0.13-0.37 mm
    0.005-0.014 in
    End Play in Crankshaft -- Worn Limits
    0.5 mm
    0.020 in
    Flywheel Pilot Runout
    0.025 mm
    0.001 in
    Rear Crankshaft Seal Diameter
    95.88-95.98 mm
    3.77-3.78 in
    Cylinder Block
    Material
    Aluminum with Gray Iron Cast-in Sleeves
    Bore
    89.5 mm @ 41 mm from deck surface
    3.523 in @ 1.614 in from deck surface
    Stroke
    92 mm
    3.622 in
    Bore Spacing - Centerline to Centerline
    102.0 mm
    4.016 in
    Deck Height
    228.0 mm
    8.976 in
    Deck Clearance
    0.60 mm Below Deck
    0.0236 in Below Deck
    Length
    442.65 mm
    17.427 in
    Piston Clearance @ 41 mm (1.614 in) from Deck Face
    0.028-0.062 mm
    0.001-0.0025 in
    Deck Face Flatness - Maximum (No Resurfacing Allowed)
    0.101 mm
    0.004 in
    Cylinder Bore Out-of-Round
    New
    0.010 mm
    0.0004 in
    Maximum Allowed
    0.100 mm
    0.004 in
    Cylinder Bore Taper
    New
    0.010 mm
    0.0004 in
    Maximum Allowed
    0.100 mm
    0.004 in
    Crankshaft Bearing Bore (Mains), Diameter
    78.073-78.085 mm
    3.0737-3.0742 in
    Crankshaft Rear Seal Bore, Diameter
    115.962-116.038 mm
    4.5654-4.5684 in
    Runout - Maximum Allowed
    0.250 mm
    0.0098 in
    Cylinder Head
    Type
    DOHC--4 Valves Per Cylinder
    Material
    Aluminum
    Combustion Chamber Volume
    56.0 cc
    3.417 cu in
    Cylinder Head Flatness Maximum Without Resurfacing
    0.05 mm
    0.002 in
    Worn Limit
    0.20 mm
    0.008 in
    Valves
    Valve Stem to Guide Clearance, New Limits -- Intake (Constant Top to Bottom)
    0.028-0.068 mm
    0.001-0.003 in
    Valve Stem to Guide Clearance, New Limits -- Exhaust (Constant Top to Bottom)
    0.028-0.068 mm
    0.001-0.003 in
    Intake Worn Limits (Not Over)
    0.068 mm
    0.003 in
    Exhaust Worn Limits (Not Over)
    0.068 mm
    0.003 in
    Head Diameter
    Intake
    36.2 mm
    1.42 in
    Exhaust
    28 mm
    1.10 in
    Valve Face Angle
    45 degrees
    Valve Seat Angle (In Head)
    45.75 degrees
    Valve Seat Width (In Head)
    Intake
    0.420-0.820 mm
    0.0165-0.0322 in
    Exhaust
    1.300-1.700 mm
    0.0511-0.0668 in
    Seat Eccentricity Runout, Maximum (In Head)
    0.05 mm
    0.002 in
    Valve Face Runout
    0.038 mm
    0.0014 in
    Valve Margin
    Intake
    0.900 mm
    0.0354 in
    Exhaust
    1.100 mm
    0.0432 in
    Stem Diameter - Intake and Exhaust
    5.920-5.941 mm
    0.2331-0.2339 in
    Valve Guide Diameter (In Head)
    5.969-5.989 mm
    0.2350-0.2358 in
    Valve Length
    Intake
    110.60-110.86 mm
    4.354-4.364 in
    Exhaust
    91.73-91.99 mm
    3.611-3.621 in
    Oil System
    Oil Pump Type
    Gerotor
    Minimum Pressure at Normal Operating Temperature @ Idle
    55 kPa
    8 ps
    Minimum Pressure at Normal Operating Temperature @ 2000 RPM
    200 kPa
    29 psi
    Oil Pressure Recirculation
    Internal Piston Valve
    Oil Filter Type
    Cartridge - Integral to Oil Pan
    Oil Capacity with Filter
    5.678 L
    6 Quarts
    Piston Rings - Clearance Between Rings and Sides of Groove in Piston
    Compression Rings
    0.040-0.095 mm
    0.0016-0.0037 in
    Oil Rings
    None--Side Sealing
    Piston Rings - Gap Between Ends
    Top Compression Ring
    0.25-0.40 mm
    0.010-0.016 in
    Second Compression Ring
    0.35-0.50 mm
    0.014-0.020 in
    Oil Rings
    0.25-0.76 mm
    0.010-0.030 in
    Number of Compression Rings
    2
    Number of Oil Rings
    2 Rails - 1 Expander
    Piston Rings - Width of Groove Ring
    Top Ring
    1.230-1.255 mm
    0.048-0.049 in
    Second Ring
    1.530-1.555 mm
    0.060-0.061 in
    Oil Ring
    2.530-2.555 mm
    0.099-0.100 in
    Pistons
    Piston Material
    Aluminum
    Piston Clearance @ 38 mm (1.496 in) from Top of Piston
    89.446-89.464 mm
    3.521-3.522 in
    Piston Pin Diameter
    20.995-21.000 mm
    0.8265-0.8267 in
    21.004-21.011 mm
    0.8269-0.8272 in
    Piston Pin to Piston Clearance
    0.004-0.016 mm
    0.0001-0.0006 in
    Pin Retention
    Snap Rings (2)
    Rocker Arms (Followers)
    Type
    End Pivot Roller
    Ratio
    1.68 to 1
    Roller Diameter
    17.740-17.800 mm
    0.6984-0.7008 in
    Valve Lifters
    Type
    Stationary Hydraulic
    Diameter
    11.979-11.993 mm
    0.4716-0.4721 in
    Lifter Bore Diameter (In Head)
    12.008-12.030 mm
    0.4727-0.4736 in
    Clearance
    0.037-0.041 mm
    0.0014-0.0016 in
    Valve Springs
    Length Installed
    35 mm
    1.3780 in
    Free
    40.790-43.690 mm
    1.6059-1.7201 in
    Valve Closed
    35 mm
    1.3780 in
    Valve Open
    Intake
    24.500 mm
    0.9646 in
    Exhaust
    man, that was a big post here's tightening specs:
    Fastener Tightening Specifications
    Application
    Specification
    Metric
    English
    Balance Shaft Cover Bolt
    12 Nm
    106 lb in
    Camshaft Bearing Cap Bolt
    First Pass
    8 Nm
    71 lb in
    Final Pass
    22 degrees
    Camshaft Cover Bolts
    9 Nm
    80 lb in
    Camshaft Sprocket Bolt
    First Pass
    25 Nm
    18 lb ft
    Final Pass
    45 degrees
    Coolant Drain Plug
    Engine Block
    14 Nm
    124 lb in
    Front Cover
    10 Nm
    89 lb in
    Coolant Outlet Assembly Bolt
    24 Nm
    18 lb ft
    Crankshaft Balancer Bolt
    First Pass
    50 Nm
    37 lb ft
    Final Pass
    150 degrees
    Cylinder Head Bolt (M11) (In Sequence)
    First Pass
    40 Nm
    30 lb ft
    Second Pass
    100 degrees
    Final Pass
    100 degrees
    Cylinder Head Bolt (M6)
    Long
    12 Nm
    106 lb in
    Short
    12 Nm
    106 lb in
    Cylinder Head Water Jacket Hole Plug
    80 Nm
    59 lb ft
    Drive Belt Idler Pulley/Generator Bolt
    50 Nm
    37 lb ft
    Drive Belt Tensioner Bolt
    50 Nm
    37 lb ft
    EGR Pipe
    Intake Manifold Bolt
    10 Nm
    89 lb in
    Water Crossover Bolt (Same for Both Pipes)
    24 Nm
    18 lb ft
    Engine Front Cover Bolt
    14 Nm
    124 lb in
    Engine Mount Bracket Bolt Front/Rear
    58 Nm
    43 lb ft
    Engine Mount Nut
    47 Nm
    35 lb ft
    Engine Mount Strut Bracket To Engine
    50 Nm
    37 lb ft
    Engine Mount Strut Bracket To Radiator Support
    28 Nm
    21 lb ft
    Engine Mount Strut Bolt
    48 Nm
    35 lb ft
    Engine to Transaxle Mounting Bolt
    75 Nm
    55 lb ft
    Engine Wiring Harness Channel Bolt
    10 Nm
    89 lb in
    Fuel Injector Sight Shield Bracket Bolt
    8 Nm
    71 lb in
    Fuel Injector Sight Shield Nut
    3 Nm
    27 lb in
    Flywheel Bolt
    First Pass
    15 Nm
    11 lb ft
    Final Pass
    50 degrees
    Ignition Coil Pack Bolt
    9 Nm
    80 lb in
    Intake Manifold Bolt/Stud
    7 Nm
    62 lb in
    Lift Bracket
    Front - Bolt (Hex Head)
    50 Nm
    37 lb ft
    Front - Bolt (Internal TORX Drive)
    25 Nm
    18 lb ft
    Rear - Bolts
    50 Nm
    37 lb ft
    Oil Filter Cap
    25 Nm
    18 lb ft
    Oil Gallery Plug
    Cylinder Head
    55 Nm
    41 lb ft
    Lower Crankcase
    65 Nm
    48 lb ft
    Oil Level Indicator Tube Bolt
    9 Nm
    80 lb in
    Oil Level Switch
    9 Nm
    80 lb in
    Oil Pan Bolt
    25 Nm
    18 lb ft
    Oil Pan Drain Plug
    20 Nm
    15 lb ft
    Oil Pump Cover Bolt
    11 Nm
    97 lb in
    Oil Pump Suction Pipe to Lower Crankcase Stud -- Nut
    10 Nm
    89 lb in
    Oil Pump Suction Pipe to Oil Pump Bolt
    10 Nm
    89 lb in
    Oil Pump to Cylinder Block Bolt
    25 Nm
    18 lb ft
    Power Steering Pump to Cylinder Block Bolt
    25 Nm
    18 lb ft
    Primary Timing Chain
    Guide Access Plug
    5 Nm
    44 lb in
    Guide Bolt
    30 Nm
    22 lb ft
    Tensioner Bolt
    25 Nm
    18 lb ft
    Tensioner Shoe Bolt
    30 Nm
    22 lb ft
    Primary Timing Chain Oil Tube to Cylinder Block Bolt
    9 Nm
    80 lb in
    Secondary Timing Chain Tensioner Bolt
    12 Nm
    106 lb in
    Surge Tank Inlet Hose Bracket Bolt
    10 Nm
    89 lb in
    Torque Converter Cover Bolt
    9 Nm
    80 lb in
    Transaxle Brace Bolts
    25 Nm
    18 lb ft
    Water Crossover to Cylinder Head Bolt
    25 Nm
    18 lb ft
    Water Pump Bolt
    14 Nm
    124 lb in
    Water Pump Pulley Bolt
    12 Nm
    106 lb in
    Yuma
    Well, I'm not a GM "tech". Hopefully, he got what he needed.
    Impatient, thanks a bunch. I really appreciate all the info. I just printed all of it out for my records. I had looked everywhere for it, thanks. The only thing I could not find in the info you provided was the rod, and mains, torque specs. If there was any possibility you could pass it on, it would be much appreciated.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    what size bolts are the darrel arp web site gives specs per bolt size
    Darrell.
    Tighten the lower crankcase bolts (1 through 16) in proper sequence.
    Tighten
    Tighten the lower crankcase bolts in sequence to 20 Nm (15 lb ft).
    Tighten the lower crankcase bolts in sequence an additional 70 degrees using the J 36660-A .
    Tighten the lower crankcase perimeter bolts (1 through 9) in proper sequence.
    Tighten
    Tighten the lower crankcase perimeter bolts in sequence to 30 Nm (22 lb ft).
    rods:
    Important: DO NOT reuse the old connecting rod bolts.
    Lubricate the NEW connecting rod bolts with engine oil and install in the connecting rod.
    Tighten
    Tighten the NEW connecting rod bolts to 30 Nm (22 lb ft).
    Loosen the connecting rod bolts until the torque reading is zero.
    Re-tighten the connecting rod bolts.
    4.1. First Pass
    Tighten
    Tighten the connecting rod bolts to 25 Nm (18 lb ft).
    4.2. Final Pass
    Tighten
    Tighten the connecting rod bolts an additional 110 degrees using the J 36660-A .
    have your machinist check and make sure we're on the same page as far as what motor we're looking at
    Impatient, you da man. Can't say how much I appreciate all the info. I just need to pull the balancer today (has to be removed to remove front engine cover) so I can get a look at all the bearings.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
