Need head gasket recommendation for a Blown 572 running 6.5 PSI
Results 1 to 14 of 34
    Senior Member 78Southwind's Avatar
    Default Need head gasket recommendation for a Blown 572 running 6.5 PSI
    The engine has a Merlin II block with 4.5 bore. The block has been O-ring (height is .010 with a bore of 4.78).
    Green Bay Wi,USA
    Are you planning on adding more boost in the future?
    I want to run the engine on 91 so probably not much more boost. The previous owner was running a MLS head gasket and it looks like there might have been water getting into the valley. However, we didn't find any water in the oil.
    Kind of expensive but these look good.
    SCE-T13524
    With their built-in oil and coolant seals, patented SCE Titan copper self-sealing head gaskets require no additional sealants. That means that you get user-friendly installation, combined with reliable fluid sealing, plus the unbeatable strength of solid copper gaskets. The fluid seals are bonded to both sides of the gaskets and cleverly offset to allow the annealed copper of the gaskets to deform around them for a better seal, especially in the O-ring combustion-seal area. Recommended for liquid-cooled racing engines with O-rings in the heads or block, these one-of-a-kind copper head gaskets can even be used on street machines with no worries about coolant leaks! For perfect sealing strength every time, introduce your engine to SCE Titan copper head gaskets.
    Dec 2010
    Sapulpa ok
    A good set of fel-pros will be fine
    If you blow a Felpro performance composite gasket out on pump gas, there is something else wrong.
    If you run 1047, the fire ring will clear the o ring groove in the block
    The SCE Titans are great gaskets, but you still have to run the ring.
    Thanks...Is this for real or will we have to run additional sealants?
    .............The SCE Titans are great gaskets, but you still have to run the ring.
    Yup, thats what we're running in our blown gas deal.
    Quote Originally Posted by 78Southwind View Post
    Gosh I hope so!!!
    Its for real the first time you use them. They won't seal the cylinder, you need o rings, but they do seal the water ports well.
    I use the same gasket except the ICS version. I just throw them on a dry clean block.
    If you reuse them, you'll need to reseal them.
    Ok, I just saw this in the FAQ of the SCE website and thought to ask.
    Titan head gaskets have silicone seals bonded to the gasket surfaces. However, some builders prefer to use additional sealant for street driven applications. If additional sealant is desired SCE recommends Copper Coat, SCE p/n G1612.
    I personally prefer not to use copper coat. If I need to reseal them, I use either their G1651 which is Valco Hylomar, or Three Bond 1194.
    If they don't seal with the bead they put on them, you need to look at your heads and block machining.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    You really do not need the o rings and copper gaskets. If it were mine I would pull the wire out and run a Fel pro MLS gasket.
    QE 439 Twin Turbo
    We have Detroit expandable graphite composite gaskets in 4.52 bore. We have both the marine and the automotive. They'll handle just about anything you can throw at them and for a whole lot less than the MLS gaskets.
    Senior Member blown86hallet's Avatar
    Belleville
    you have them for BBF 4.56 bore?
    "Jealously" is an ugly emotion!
