Dyno-Flo ???----henderson Nv.
Results 1 to 13 of 13
    DLE
    DLE is offline
    Default Dyno-Flo ???----henderson Nv.
    Has anyone had any Luck/bad-luck with there short-blocks
    RAT PATROL rich s's Avatar
    S central Pa.
    Quote Originally Posted by DLE View Post
    i know one person that got a 496 short block from dyno-flo, it is in a sanger flat. 2 carbs N/A
    so far it is making good power , we put about 20 or so
    1/4 mile passes on it,plus 20 minutes of break in on the trailer.
    he is running a Oberg filter and every time he opens it up to inspect it.
    it has metal chips and sh!t in it.(more crap then i care to see) (does not look like bearing material) it only has 75 lbs of oil pressure,we have changed the oil 3 times already.
    i am not sure if it is going to live or it may be eating itself up.
    i told him tear it down and have it checked out. just to be on the safe side. time will tell.
    Atlantic Beach, FL
    Peoria, AZ
    I have not purchased an assembled short block, but have two short block kits that we put together and are running. One is in a Seven second dragster and the other is in a dragster running in the 8.30 range. We found some issues with the injection system and expect to see an increase in performance over the 8.30 times. We have not had any problems with either of them.
    Paul
    Member Aaron's Avatar
    Brigham City, UT
    Good feedback from me...... I bought a 532 BBF shortblock from them for my boat, and it is doing great. Not too much time on it yet, but I'm happy so far.
    I'm in northern Utah, and they shipped it in a timely matter.
    Kingman/Golden Vly, Az
    Quote Originally Posted by Aaron View Post
    that is 1 "nasty" lookin' motor & awsome lookin' boat! ...how fast have u had her?
    FastRat
    Fwiw he told me it hit the rev-limiter k-wick at 5800 with a A cut.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I bought 2 rotating assemblies from them. recently within the last month.
    They did not deliver even close to when they said they would.
    They came balanced. We re-balanced them.
    and.. when parts were mixed up in shipping. They said they do not do tracking numbers. Don't worry they will show up.
    They eventually showed up but absolutely no peace of mind. Could not follow up on anything.
    When asking for the person that sold me the parts. 90% of the time he was not available to talk and the other guy could not help me with my questions because it was the other guy that helped me.
    Long story short. I eventually got everything but was extremely uncomfortable with the entire transaction. And if i could have not rebalanced them, would have had to pay to get it done. But would not have known any different if not capable of checking it myself.
    The Eagle parts were less expensive than buying from Eagle direct but the tolerences were worse than buying from Memphis.
    Live and learn I guess. There is always some "get what you pay for" in everything.
    I bought a crank from them when they first started on ebay listed as a steel in good cond. needed to turned to 10/10 even could see that with the open eye. gave me alot flak as did not say that wasn't in need of resizing. what a jerk.
    "BOUGHT NOT BUILT" 2FORCEFULL's Avatar
    @ The Islander OutCole'd's Avatar
    Vegas
    Hear say?? Just curious?
    <img src=http://www.performanceboats.com//signaturepics/sigpic640_1.gif border=0 alt= />
    I bought a bare block from them. Was supposed to come machined to my specs. Bore was .002" oversize, deck wasn't decked and lifter bores were not honed. Bottom line for me, good deal on parts, but do your own machining and/or assembly.
    Smokin Whitie hondo jim's Avatar
    Northener
    G935 bought a motor from them compleate had dyno sheet for over 1000 hp with eagle crank rated for like 700hp drove from fresno and picked it up ,when got it home was full of metal and worthless.ass out ask him
