Breather gasket or not?
Results 1 to 8 of 8
    Senior Member johnf's Avatar
    Oct 2012
    Default Breather gasket or not?
    Got some new to me breathers. Whats the best way to keep from leaking? Use a gasket(what type) or just use some Right-Stuff and bolt down? Or Both? Thanks for any help. Johnf
Name:	001 (1024x766).jpg
    Quote Originally Posted by johnf View Post
    I use clear silicone carefully applied so it doesn't show.
    Senior Member jdekruyf's Avatar
    Jun 2011
    Artesia, CA
    I use gasket maker. Let it skin over a bit then clean the excess off the next day.
    Senior Member OLD MAN ON THE LAKE's Avatar
    Phoenix
    Nice looking breathers.
    Nov 2009
    X2
    I have breathers very similar to yours that I bought from Rex, mine had an o ring on the bottom side that sealed perfectly with no sealant required. I mounted mine on the upper vertical surface closest to the intake to put them behind the oil spray coming from the valve train.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    Oct 2012
    Quote Originally Posted by OLD MAN ON THE LAKE View Post
    Thanks Tom going to work out nice!!
    Senior Member steele211's Avatar
    Nov 2008
    Kingsburg,CA
    I took black rtv applied real thin let is set for a couple days and bolted them down. No mess to clean and sealed up nice
