downsides of a 400sbc block?
Results 1 to 14 of 68
    Default downsides of a 400sbc block?
    guys, are the 400 blocks pretty weak? only thing i can remember about them is the cooling issue, but that's a non issue in a jetboat. what were the other downsides? i've got a nice block, just didn't know if its worth using of if i'm gonna have to make this a 2yr project, buy a lil m block
    I'd think the lack of head gasket surface(siameesed cyl walls) would make head gaskets a challenge with a boosted appl.
    Cantard 71hallett's Avatar
    snow bank
    They start splitting at about 650 - 700 hp.
    snow bank
    You put those heads on it that I sent you the link to and you will need a dust pan to pick it up. lol
    one would think that this would be one of the big problems, but evidently it isn't because the rocket and dart blocks are used for high boost, big spray, and big compression, and they have the same bore spacing. it's all in the head gasket you use, and the fact that the block doesn't move around as much.
    snow bank
    the 4 bolts are pure junk
    You got that right!! Why they built a block with bolts that thread into nothing is beyond me.
    I don't see where you mention forced induction here, maybe I missed something.
    We run 400 blocks in a dirt modified that I build engines for. We had a destroked combination that we were running in a 4 bolt block on race gas, no issues except the bore was a little tired and we went to a 2 bolt block for this year.
    i've got a 2 bolt, thought i could 4 bolt it with splayed billet caps, maybe get 1000hp outta it with some boost. what is making them split at 700hp?
    snow bank
    Broken mains. Should be able to buy a block for about $1900
    found a boat to put it in, he's sending me pics tonite lil 17ft predator, so i'll be buyin the lil m block for this project. this will be my 1st 2yr project, so next summer will be spent on the toon
    the whole block jumps around, but the biggy is like 71 Hallett says, it will show up as broken mains before anything else
    thanx for the info guys, looks like i just need to freshen up the 412sbc and put it to the side for a spare i'll buy a lil m block.
    New here Beer:30's Avatar
    Bakersfield, CA
    Default Motown
    Motown Cast Iron Blocks
    At first glance, one of the more noticeable differences between the World Motown and OEM Chevrolet blocks are the “bulges” at each cylinder. That’s because the “Motown” has thicker cylinder walls, and the water jackets have been expanded to provide required cooling. The Motown block can be bored to max of 4.200". DO NOT EXCEED.
