Congrats TNYoungblood and Scott Foxwell on a job well done.....
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 117
    Tri-Cities, TN
    Default Congrats TNYoungblood and Scott Foxwell on a job well done.....
    I will let TN have the honor with the details tell but I must say that his engine is the 2nd best 496 that I have ever had the pleasure of putting a Straub camshaft in
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Thumbs up
    C'mon with it mike!! Saw the warm up vid on fb
    Mar 2010
    Clarksville, TN
    Whata Beast !!!! Damn thing made almost 900 Hp.
    Big thanks to Scott Foxwell and Chris Straub for this one, turned out awesome.
    If anybody needs anything done engine wise these are the guys to call. 1st class all the way
    May 2012
    TORQUAPOWA that is a bad ass torque curve very nice
    it was putting a kink in my neck
    Looks like the fuel was going left when the air was going right. Imagine the power it could have made if you fixed that.
    You let Foxwell play with that manifold?
Name:	dyno sheet.jpg
    Mar 2010
    Clarksville, TN
    Ya he rubbed on it alittle
    She's fat but gonna see what it does when I get off this mountain.
    Close to the water...
    Do you think a stack MFI would work on that beast
    Mike had the short block built by someone closer to where he lives. I worked the Canfields and the TR, and Straub did the magic wand. Mike came out Wed night and we spent yesterday getting the engine assembled and ready for the dyno.
    Fuel was plenty fat on this one. Probably another 10-15 in getting that cleaned up. First pull right out of the gate was 850 hp. 678 tq. Spent most of the day chasing an oil pressure issue. Once we got it sorted out, removing one quart was worth almost 30hp. We did a lash change and a timing change.
    Day on the dyno; 42hp, 24lbs ft. lbs ft.
    She's stout to say the least.
    That would be interesting.
    I seriously doubt its off there far bank to bank.
    Senior Member bp298's Avatar
    LHC
    mike, is this going in the Cheyenne? what were the observed numbers???
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Should run 9.00 in the Cheyenne on the motor.
    LHC
    Quote Originally Posted by PCE680 View Post
    now he'll need to go get a physical and a license...
    Thumbs up
    Lol yep.
    it sounds wicked in the warm up vid mike did you get a pull vid? Congrats on a awesome piece!!
