Dyno day 1
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 119
Dyno day 1
    Senior Member TexasJet's Avatar
    College Station, Texas
    Default Dyno day 1
    We got a late start, so we only made 4 or 5 pulls.
    To get a base line we started with 27 deg timing. Carb jets 93 square. Pulleys, one to one = 5 lbs of boost. 4500 rpm max.
    Last pull was 27 deg. 93 square, 8 lbs of boost. Dyno locked at 5500 rpm max.
    Results as follows: 927 HP. Running rich.
    Monday: More timing, probably up to 30 deg. smaller jets. 12 lbs boost and let the rpms run.
    I want to hold the rpms to around 6500 but Joe says this engine will make more power way past that rpm.
ID:	500881   Click image for larger version.
ID:	500889   Click image for larger version.
    Jan 2011
    Mickleton, New Jersey
    Quote Originally Posted by TexasJet View Post
    How big is the engine?
    540 ci and it has one of those famous Straub cams.
    Tri-Cities, TN
    This on Owens Dyno?
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Yes. He says he knows you from "back in the day", like years ago.
    Tri-Cities, TN
    Yes back in the 90's we did business. I apparently have had 6 or 7 on his dyno over the last 2 years. A 434 SBC that he dyno'd a few months back apparently really caught his attention. I look forward to working with him again.
    Chris Straub
    Straub Technologies
    We will know today what the final numbers are. It's gonna be a loooong day.
    Tri-Cities, TN
    Do I here a 1000HP yet?
    Chris Straub
    Straub Technologies
    Better be more than that! No word yet. Argh!!!!!!!!!!!!!
    Pump gas or?
    How bout some details.
    Senior Member Skydog's Avatar
    Jul 2010
    Thumbs up
    Good luck! Yea pump gas 93?
    108 fuel. 540 CI, Dart block, Dart 345 complete CNC aluminum heads. Stainless inlet and inconel exhaust. Dragonslayer blower crank. Coated pistons. 2 1050 dominators. 1071 Littlefield blower, just rebuilt. Intercooler. Straub "top secret" cam.
    Dyno today, I guess. Looking for 1100+ HP at around 6500 rpm with 12lbs boost and 28 or 29 degrees total timing. Headers are Basset big tube blower headers with slip in high po mufflers.
    It's going in a 19' California Performance jet. Will need a new impeller, probably A or AA hi-helix race prepped. Pump blueprinted by Mike at Central Texas Jet. Mike's a young guy with a lot of pump knowledge that has just started his own shop. He has done work on by boats before and I've been very pleased with the work.
    Hoping to see 120 MPH.
    Anything else I missed? TJ
    120 in a 19 GW... be careful.
    As much as possible.
    I will only do that speed under ideal conditions. An then, not very often.
    Next winter we will put in a pop off valve. That's gonna require some fibreglass work.
