Holley Floats
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 49
Holley Floats
    Lake Havasu
    Default Holley Floats
    I have a 496 bbc with two 1050 dominators sitting sideways on a tunnel ram. The engine makes 800hp, and I'm using a Clay Smith 140gph mechanical pump, and the pressure is set at 7.5#. Here's my problem, the boat launches hard then lays down then accelerates again. I was told that the side mounted copper floats I have may be causing the problem by cutting off the fuel at the launch. It was suggested that I change to center mounted floats, the black notched ones. What do you think?
    Senior Member Pattymelt18's Avatar
    Thats what i use call c&j get the weighted ones they work great.
    MI
    I run the notched floats. Helps the float level in ass heavy boats.
    Senior Member The Violater's Avatar
    I have a 496 bbc with two 1050 dominators sitting sideways on a tunnel ram. The engine makes 800hp, and I'm using a Clay Smith 140gph mechanical pump, and the pressure is set at 7.5#. Here's my problem, the boat launches hard then lays down then accelerates again. I was told that the copper floats I have may be causing the problem by cutting off the fuel at the launch. It was suggested that I change the floats to the black notched ones. What do you think?
    Do you have a fuel log , or just lines and a T? With no log and by-pass regulator you could be running the lines dry.
    / The Few The Proud TheBlown
    The Right Coast/SE-PA
    A 496 w/800 HP...give some engine details man!
    Lake Havasu
    Quote Originally Posted by The Violater View Post
    No fuel log. I just have -6 hoses from the Product Engineering fuel regulator to each bowl. The regulator is a by-pass but I have the return plugged. Could it still be causing the fuel shortage?
    Lake Havasu
    It's not a GM 496. It's an all aluminum Keith Black block with Dart heads, JE pistons 14.5:1.
    I'm so dumb,I thought notched floats were to clear jet extensions?????
    Lake Havasu
    Yes they are, what's your point?
    I thought your carbs were mounted sideways? Or are you a roundy round guy?? Nevermind...Sorry.
    Lake Havasu
    Okay, I think I'm missing something here. Yes, my carbs are mounted sideways. Are the center mounted floats not for sideways mounted carbs, or is it the extensions? I'm just trying to understand....
    When I bought my jet extensions and notched floats it was for a different reason than why you did/are. I bought them for the back bowl of my holly. (carb mounted fwd.). Like I said Sorry....nevermind
    MI
    Now I'm lost. I was talking about the roundy round floats not the ones for the jet extensions.
    Lake Havasu
    Yeah, I'm getting lost too! All I really wanted to know is if the black notched, or non-notched floats, that are center mounted will prevent the float from shuting off fuel when my boat launches. The current brass floats are side mounted and with the carbs being mounted sideways "I think" they are shuting the fuel off as the gas surges to the rear under a launch. I don't know if there is any advantage in having jet extensions? Additionally, I wonder if my pluging the bypass port on my regualator may be causing the problem, maybe flooding the engine? Any help or suggestions are greatly appreciated.
