Stripped Hole Fix?
Results 1 to 14 of 37
Stripped Hole Fix?
    The Right Coast/SE-PA
    Question Stripped Hole Fix?
    He fellas, besides a Heli-Coil etc is there anything on the market or tricks out there to get this 5/16 x 18 bolt to bite and hold 13 lbs of torque?
    It's from my Vette transmission Valve-Body that threads into the aluminum case, I never even got to torque it, I just snugged it up and it pulled the threads out!
    I thought about inserting a strip or two of thin solder or thin wire to displace the metal and make it bite > like the old wood-screw trick.
    I would HATE to pull the valve body-off again, I just put it on!
Name:	Valve Body Bolt.jpg
    Lake Havasu az.
    Any threads left in the bottom of the hole? You might be able to run stud in it.
    Sheriff Joe Arpaio
    Great idea...there are a few, and the hole is deeper than the bolt.
    If there was some hard core epoxy to go with a stud, that may do it!
    Kent, WA
    Time-cert
    Time-cert
    I'm trying to NOT remove the valve body.
    Bottom tap the hole, pick up a couple more threads and JB weld a stud in there. Let it sit for a day then run the nut on.
    Is the whole blind? How many threads do you think are below the bolt length? What the bolt size?
    Like the old saying goes, never enough time to do it right, but always time to do it over.
    I think it takes less that 10 minutes to pull the valve body. He could have it out in the amount of time it takes to post on it.
    That would be my suggestion, if the hole is blind. If it isn't, the JB weld will run out of the hole before it setup, into the trans. Unless he can plug the hole somehow.
    hey Scott, I'm hoping to avoid pulling the valve body as I don't know if the two new gaskets will be resuable and I can't replace them without buying a paper kit.
    that's why if you read my first post I asked if there were any tricks to use or MAYBE something over the counter that would work vs a Time-cert or help coil.
    We're not talking head bolt torque here but 13 lbs.
    I'm not about doing things half assed, so no need to toss your jab in there for 'asking' if there's another option.
    GN...yes the 5/16 hole is blind.
    I gave you as good a suggestion as I could, but I'm also giving you the best advice I can, having been there, done that enough times to know; buy another paper kit if you have to, take the thing apart and do it right or as sure as I'm typing this, you'll wish you had, in the end. Sorry if you don't like my answer, but it wasn't meant as a jab.
    If you use a stud, ignore the release part. And you don't need Permatex/Locktite kit. JB weld will work just as well. Clean both the stud and hole with iso alcohol.
    I would let set overnight.
    The bottom tap and stud idea worked fabulously...that hole was almost 5/16" deeper.
