468 oil problem?
Results 1 to 2 of 2
468 oil problem?
    Dec 2012
    Default 468 oil problem?
    I recently had my boat engine rebuilt at a local but reputable machine shop. Cyl bored,line bored,new pistons,crank turned,new cam etc. Did all the proper break-in procedures. It stared losing oil pressure at idle. Drained oil and found metal. Took engine back to the builder and he found no.2 and 4 mains where toast. He's not sure what caused this. Did I get a bad line bore or did the crank guy f up?
    Quote Originally Posted by nevada hondo View Post
    If it was a align bore, or the crank, the builder should have caught it . That's the difference between a guy that builds engine and a guy on the assembly line. Out side of you not paying attention to the oil pressure or an inadequate pan design etc, it makes no difference the what or why.
    Lower ends, specifically bearings don't just fail. Somebody screwed up. You, or the builder. Take your pick
