Time for bearings
Results 1 to 14 of 20
Time for bearings
    Colfax, Ca
    Default Time for bearings
    It did make a noise!!
    Is this real or the "Twilight Zone"?
    Douglas, MA
    have the crank checked before you throw the bearings at it.
    Senior Member Roaddogg 4040's Avatar
    Lake Havasu City, AZ/Algonac, MI
    Looks like ya got your monies worth out of those bearings...
    Steve
    Concord, CA
    Default bearings
    Crank, rods, and the installer/operator. Damn, you had to hear and smell that before she let loose. If you need crank and rods, I have an extra set laying around.
    Do you by chance have an intake. I need a single plane, standard deck, 4150 flange intake for a simple project.
    Jerry
    Colfax, Ca
    Hi Jerry
    Don't know what I am going to need. Need to finish tearing it down. I don't have an intake, sorry.
    Give me a call this weekend
    Colfax, Ca
    Finished tearing it down. Everything else looks good. This was an unknown engine. Possible reasons for 5 & 6 to go and the rest look good?
    Colfax, Ca
    Is there any chance of some input here?? I am trying to learn. Even old guys may want to learn something! Sheesh
    You said unknown engine so cld be possible that journal was bigger than the rest after it being turned or maybe bent crank/crack
    Nov 2009
    Jerome, Idaho
    The old guys have already learned from mistakes, your dealing with trying to put a band-aid on a gaping wound, no cheap correct way out on this deal.............................
    Colfax, Ca
    Spudpilot. Not sure what you mean. Am not looking for a cheap way!! Looking for knowledge. Conversation as such
    Nov 2009
    Jerome, Idaho
    OK.......You need to take this pile to a repeatable machine shop in your neck of the woods (Sacto, Grass Valley or Reno area) that can give you the straight facts on what you have!! The chances of the crank being any good are nil, also the pistons on those same holes were smacking the head, so as I see it minimally: a Crank, 2 rods, 2 pistons, oil pump, check out heads, rings, bearings, gaskets, vat & mag, hone block, check weights for balance, etc.
    Hope this helps.............. John (208) 731-7999
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    Quote Originally Posted by Spudpilot View Post
    Good advice right there
    Colfax, Ca
    Thanks Spudpilot. I had every intention of doing what you suggest. Not quite understanding the derogatory remarks. But hey, us old guys can roll with it. That is how we learn.
    Nov 2009
    Jerome, Idaho
    Sorry, wasn't trying to be derogatory with my input, but felt it getting a bit stagnated as to what you were suppose to do!
    I apologize.................. I'm a day older tomorrow so I guess I'm cranky!!!!!!!
    Cheers & Good Luck!
