Any Advice for a blower newbee
Results 1 to 14 of 27
    Senior Member cave's Avatar
    Mesa, AZ
    Default Any Advice for a blower newbee
    I'm real close to getting the motor all back together. Once its done and back in the boat, What advise would give me. I plan on running under driven @ around 6 to 7%. For a few runs
    Engine:Gen VI 515 BB Chevy. Rotating assembly has been spun & balanced & Line Honed. New SRP Flat top Pistons & rings. 119 cc Open port GM Performance aluminum heads. Had a valve job done too. Comp ultra gold Aluminum Roller Rockers, Hi tech push rods, Comp Cams XM298H w/ Chevy Hydraulic Roller Lifters. RPM Range 3200 - 6800
    Intake 298 duration .575 valve lift.
    Exhaust 316 Duration .578 valve lift. Dyers Roots type 6/71 blower. #33 and #36 Pulleys. MSD dizzy & 6al box
    I got a heavy right foot and its right over the throttle pedal.
    Takin it home
    Senior Member Deltarat's Avatar
    Discovery Bay Ca.
    My advice is don't smile too big, you'll get bugs in you teeth
    Do not go out and over drive the boat until you get used to the new set up.
    What happens on the Delta stays on the Delta
    Cantard 71hallett's Avatar
    snow bank
    Quote Originally Posted by Deltarat View Post
    x2 lol
    Have to get us a pic when your done.
    Congrats.
    Mesa, AZ
    Just got my camera working again. No more pictures in the dark without a flash here are a few from the camera phone
    Thanks guys. I hope its as fun as you both say.
    Takin it home
    In a house, on a street, in a city, in Arizona.
    Next to the oil pressure gauge, the most important thing you're going to want to watch religiously will be your fuel pressure, especially when you're heavy right foot is in action. Bad things happen fast if you go lean.
    snow bank
    Looks good Cave.
    Mesa, AZ
    Quote Originally Posted by jordy View Post
    Yea I here you Jordy
    This was ex psi canyon (Matt). I believe this was caused by a lean condition.
    Takin it home
    Atlantic Beach, FL
    How are the carb spacers working out? I haven't noticed the circle racers using those with blowers, but the guy at BDS said they have found HP improvements with 1" spacers.
    Curious about your experiences with those.
    Ps. I came across a fuel flow rate gauge recently. I'm thinking that might be a good companion to fuel pressure.
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    I could teach you a couple of things. I'm what you can a vetren Cave lololol . I do agree with jordy, if you what the fuel pressure gauge as it starts to lean out you'll start to here a poping, thats no bueno
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Mesa, AZ
    Can a vetren cave?? Get some rest buddy. ANd thanks for everything bro
    Thanks Admin for the correction in the title ((Blower))
    Takin it home
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    [ as it starts to lean out you'll start to here a poping, thats no bueno[/quote]
    CAVE,you have to remember to not have any throttle input,when you are starting it. This will cause a lean condition,
    Mesa, AZ
    Quote Originally Posted by FARMER JOHN View Post
    CAVE,you have to remember to not have any throttle input,when you are starting it. This will cause a lean condition,[/QUOTE]
    A lean condition when Pumping the throttle? Wouldn't that flood the carbs? Or did I miss some thing FARMER JOHN
    I read in another thread that when you start a blower engine you pump the throttle a few times then wait a moment. Then start it up. Once it starts you need to keep the revs at about 1100 till the engine warms up. Please correct me if this is wrong...
    Takin it home
    Sep 2008
    DOME VALLEY,AZ
    Right, i usuly just let the motor go to idle after it starts
    snow bank
    I read in another thread that when you start a blower engine you pump the throttle a few times then wait a moment. Then start it up. Once it starts you need to keep the revs at about 1100 till the engine warms up. Please correct me if this is wrong...[/quote]
    On mine after it has sat for a week or so 2 pumps max turn key and let it idle. For me any more that that I end up pullin the back 4 plugs cause there soaked and other boaters dont seem to like my language.
