Six valve mech pump question
Results 1 to 9 of 9
    Feb 2010
    Default Six valve mech pump question
    How much HP would a six valve bbc mechanical pump support? The ones i have are the older holley 712-454-1 pumps, with the 1/2NPT in/out. These are the preset psi ones, that dont require a regulator. blown carb setup. Thanks!
    Quote Originally Posted by Mild Thunder View Post
    They will support 1200 HP. The pressure has very to do with the volume have very little to do with the volume they will move. But you do have to pay attention the line size in and out. A -10 in enough if the line isn't too long with too may fittings. To -10s to a Tee or tank switching valve, and a -10 from there will work.
    a -8 to each side the carbs, split to feed the bowls on each side will suffice
    Either run the -8s from a Tee manifold like Teague sells that screws right into the pump, or run a -10 to a tee that splits into two -8s and then two -6s for the bowls.
    The secret is keeping the line size up.
    Feb 2010
    Awesome. I've always had good luck with these pumps in general. Love not having to use a regulator. Why on earth did holley stop making these ?
    I don't know why dropped them. Their new HI PO pumps are billet. Edelbrock dropped as well. But they are still made by Clay Smith, C&S, and Baker Engineering/ProCam and maybe one other.
    Baker Engineering is the only one I know of assembling them in the lower pressure configuration. But you can lower the pressure on any if them by removing the inner spring inside.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Buy the Clay smith pump. They are a great deal. I ran countless numbers of them and never an issue.
    QE 439 Twin Turbo
    Feb 2010
    Can you get them in the low psi for no regulator, or do you need to remove a spring
    Tri-Cities, TN
    The Claysmith will support what you need. George has a nice fuel log/regulator that he does. Give them a call Monday.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Only Baker Engineering/ProCam sell a 7 1/2lb pump. Same pump Teague sells.
    New Port Richey, FL
    I's always better to pump more fuel than you need and bypass what you don't need.
    QE 439 Twin Turbo
