[Question] Isky hydraulic lifter question???
Results 1 to 14 of 16
    Colorado Springs
    Default Isky hydraulic lifter question???
    I have a set of Isky 3970-HYRT lifters. I was going to run them in a mark IV. I now have a dart based 540. I was told by Isky that they will work in a Dart block. I didn't think they would work in Darts tall body lifter block. They are reboxed Merrels I guess. Also, how much lift cam I run for a 6500 rpm motor. I am running a set of Jessel pro 1.8s on a set of AFR 357s. Thanks in advance!
ID:	511666   Click image for larger version.
    Tri-Cities, TN
    The reason we have tall lifters is becasue OEM hyd rollers are taller. A Morel link bar lifter will fit in a Mark 4 or a GEN5/6. Morel lifters built after Jan 1 2014 have the new valving design. For any sustained runs I would recommend this lifter.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Quote Originally Posted by jungledave View Post
    No, the Isky's will not work in the Dart block without notching the block for the link bar. Like Chris posted, Morel does have a lifter that will.
    Colorado Springs
    Thanks, problem is I own them and Isky only carries that part number. I am actually going to run the 540 in a 69 chevy short bed, sold or selling my boat stuff. I may just have to notch the block then. I understand the oil galley is in the same spot but the lifter hole is taller. The lifters I have are the Morels with the .750 wheel but since Isky only offers this lifter I am stuck with them, maybe I will be able to trade them for some solids and forget about the hydraulic stuff. Thanks
    If it's a Morel lifter, it'll work in the Dart block and the picture in Isky's catalog looks like a Morel.
    If you can post a pic of what you have we can say for sure.
    The Morel 4603 (which is what this most likely is) will take high .600" lift and 7000+rpm with the right springs and correrct rocker geometry.
    If it's a hyd roller with a tie bar it's a Morel.
    Colorado Springs
    I posted pics in my original post. The heads have 1.8 Jessel Pro rockers. I was hoping to run .700 lift or very close to it, the AFR 357s are big for my combo but I own them. I was also wanting to make sure the 1.8 will work with hydraulic lifters. I'll have to ask Chris to spec me a cam. Money is tight right now, I lost my job last Wednesday. I also have a new ISKY roller that I can mock up, but it is only 600 lift and is probably too small to have Isky regrind for the lift I need. Thanks for the help guys!
    Here is a Morel 4603 BB Chevy retro hyd. roller lifter. You be the judge. This will work in all Gen and Mk blocks, Dart, World, Bluprint, etc.
    You need to run 200-225 seat pressure and 500-550 open pressure with as much cam as you're going to want to run. I don't think you'll need any where near as much cam as you think, but I'll leave that up to Chris.
    Senior Member stoker2001's Avatar
    Folsom,Ca
    pretty amazing a "juicer" can take that much springhow much preload?
    Whacker Smacker M/E #561 IHBA "first looser"champ 2006&2007&Sportsman Driver of the Year
    Quote Originally Posted by stoker2001 View Post
    They seem to run best with 3/4 - 1 full turn, 10w40 oil max.
    Live and learn. Looking at the picture Jungle posted that wasn't up there, and the hyd rollers I had seen before came out of Shaver Engineering, they did not fit Dart and Gen 6 blocks.
    Good to know.
    Colorado Springs
    That's why I love this forum, I learn so much from you guys!!
    Good to know.
    Actually Shaver has some that will work with the .300" taller bore.
    Colorado Springs
    Thanks again. I would like the engine to make 800hp, which shouldn't be that hard with the 357 head I hope. I just know that the head needs as much lift as I can get if I am running a hydraulic roller. But I am not a builder, just an assembler and internet troll
