methanol 14:1 and vertex mag
Results 1 to 10 of 10
    May 2012
    Default methanol 14:1 and vertex mag
    does the vertex mag put out enough juice to light off methanol with some heavy squeeze or can it be modified to do the job
    I have a recently refreshed mag and have been day dreaming about running methanol do I need have it sent out and wound hotter
    before you guys tell me to sell the mag and run coil on plug save the breath this build is "period correct" on the outside
    Nov 2009
    Jerome, Idaho
    Run It!!!!!!!!!!!!
    Quote Originally Posted by bowtiebro View Post
    You mean the same mag they used to fire fuelers and funnies in the 60s and 70s, or turbo Offys with 50lbs of boost and 12 to 1 on meth?
    Ya, I think its up to the job,
    Senior Member PropWorks West's Avatar
    Jan 2010
    Lake Havasu
    Mr Gorr from Gorr Fuel systems will tell you thats one of the best for that set up.
    I run one and have great success with it
    May 2012
    I wasn't sure if they were all wound the same out of the box that's why I questioned it, a few of my friends run external coils on there enduro boats for longevity due to internal coil failures so I know they might all look the same but the guts can be different
    May 2012
    Quote Originally Posted by Spudpilot View Post
    Run It!!!!!!!!!!!!
    oh It will be run, and run hard if im at the loud pedal I guess im going to have to get me some new carbs
    Jan 2010
    Lake Havasu
    The down side to the vertex is that after so much run time, the magents need to be recharged. You can get around that by having the rare earth magenets installed, plus they give a tickle more punch
    Kent, WA
    Depends on how much cylinder pressure there is !
    Jan 2011
    Mickleton, New Jersey
    Cranking speed is very
    important also.
    Nov 2009
    Jerome, Idaho
    Run It!!!!!!!!!!!
