Opend End Wenches
Results 1 to 14 of 14
Opend End Wenches
    Apr 2010
    Rocklin, Calif.
    Cool Opend End Wenches
    This is stuff I think about...who desinged and knew the proper angel, when useing a open-end wench
    They allways seem to fit..
    Jun 2010
    Solymon Merrick patented the first wrench in 1835.
    Maple Ridge B.C. Canada
    Are we talkin Wrenches or Wenches???
    Quote Originally Posted by mdsheppie View Post
    But not the angles and offset of a combination end wrench. I believe that was worked out in the factories during WW II.
    Quote Originally Posted by rogerroost View Post
    Or wenches with wrenches??
    Default Proper ???
    I'm quite sure I'm not alone when I say I have "modified" a few for a more proper fit... More so the box ends, like for the front inner bolts of an Enderle hat, but also a pretty good collection of bent up open ends when the designed "proper angle" just wasn't quite right.... Boats are easy compared to cars/trucks that have assembled drive trains before the body goes on... Just once I'd like to see a GM, or Ford, or Chrysler engineer have to work on their stuff when it is a completed assembly.... I won't even get into the "special angles" required when dealing with aircraft or ordnance.... You see, those "cheap" tools are good for something....
    Ray
    LOUD BOATS SAVE LIVES
    Denton, TX
    My question is, why do we need SAE and metric. Pick one and stick with it. My old chevy was built in Canada and and a mix of both were on there.
    The rest of the world did! Just you guy's are just a little behind. this is a map of countries still on the imperial system..
    Apr 2010
    Rocklin, Calif.
    [QUOTE=Moneypit;3085330]I'm quite sure I'm not alone when I say I have "modified" a few for a more proper fit... More so the box ends, like for the front inner bolts of an Enderle hat, but also a pretty good collection of bent up open ends when the designed "proper angle" just wasn't quite right.... Boats are easy compared to cars/trucks that have assembled drive trains before the body goes on... Just once I'd like to see a GM, or Ford, or Chrysler engineer have to work on their stuff when it is a completed assembly.... I won't even get into the "special angles" required when dealing with aircraft or ordnance.... You see, those "cheap" tools are good for something....
    Ray[/QUO
    10-4
    I have modifed hand tools to suit my needs, like everyone else...I was amazed yesterday how you can usually grab atleast one flat when needed
    never paid that much attention before..............
    Hey we are converting to the metric system inch by inch!!
    [email protected]
    Ohio
    I replaced a water pump on an 82 GM 2.8 once. It had 9 bolts holding it on. 6 were two different sizes SAE and three were metric. Guess they couldn't make up their mind.
    Tim
    Tim
    The 2 metrics were factory fixes for stripped threads
    Apr 2010
    Rocklin, Calif.
    I replaced the shocks on my dads 97 3\4 chevy truck...uppers metric, lowers sae ???
