HP guess...532 pump gas BB Chev
Results 1 to 14 of 35
    Default HP guess...532 pump gas BB Chev
    Any guesses? Going on the dyno Tuesday.
    532 ci, Dart Big M, 4.60 Mahle pistons x 4.0 Scat crank, 10.6:1, 6.535 H beam rods.
    AFR 305's ported to 325cc, 2.325 valve, 400cfm @ .700"
    Ported Super Vic intake with a QF two circuit 1050, no spacer.
    55mm custom Straub hyd. roller, .750+, 260's @ .05
    Morel .903 hyd. roller lifters
    7/16 Smith Brothers pushrods
    1.65 Crane gold rockers and AFR stud girdles
    MSD crank trigger
    Stef's kickout pan.
    Mar 2010
    Clarksville, TN
    Senior Member Franger's Avatar
    Aug 2011
    Wasilla, Alaska
    okie, lake Texoma
    General consensus is - if it had a 4150 instead of that junky old quickfuel it might make some steam.
    H8-2-W8
    [email protected] first pass
    That the best you can do?
    I think later this year we'll be doing a TT version of this engine.
    The member 1bdhondo's Avatar
    ca
    750 assuming max rpm at 6500 more rpm maybe a little more
    why no spacer ?
    hood clearance ?
    why no spacer ?
    hood clearance ?
    Yes.
    Yes.
    hyd rollers typically throw me off, but I'll throw out 800+/- 10
    WV
    280 Profile Cat W/575sci JRider's Avatar
    Lansing MI / Deerwood MN
    Quote Originally Posted by Hass828:3088034
    My new motor has a quick fuel carb. I am not familiar with them...what is the drawback?
    Quote Originally Posted by JRider View Post
    There isn't one. It's just Hass being Hass.
    Well considering that Holley now owns both BG and QF and has for a little while, its doesn't say a lot for Hass's BS claim
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    At what RPM's should the HP guess be?
    QE 439 Twin Turbo
