Just want to check
Results 1 to 14 of 32
Just want to check
    Bullhead city AZ
    Default Just want to check
    On the torque specs for a BBC using ARP headbolts... Now my Chiltons book said 80pounds but did some checking and it seem it's more like 75 pounds long bolts and 65-68 short bolts.
    I torque'd everything to 80.
    Who can give me the correct torque for these heads with ARP bolts..
    Everyplace i look i see conflicting #'s
    LaGrange GA
    Don't go by the Chiltons book. Use the instructions that ARP gives. There should be different numbers depending on what lube you use too.
    Default Oops!
    Quote Originally Posted by 468Bahner View Post
    Too late..............The head bolts came with INSTRUCTIONS. Right?....ARPs are not the same as the stockers, so using stock specs is wrong, period. Fastener torque is an industry wide practice in an effort to make it easy for the average DIY guy to stretch the fastener to the proper tensile load. That is why the Chilton, and most other STOCKER books list a different torque value for the long and short bolts. ARPs are not stockers, and the torque value in the ARP INSTRUCTIONS is based on what it takes to get the PROPER bolt stretch for the aftermarket ARP bolts using ARP thread lube. ........So, what do the instructions say?...............MP
    PS: BBC head bolts are live to WATER and should be sealed with silicone to prevent leaks, both outside, and inside the valve covers. A leaking head bolt inside the V/cover will pollute the oil, outside leaks are just a pain in the ass. ARP thread lube is not a sealer, and if you oil the threads the silicone won't stick. Both are very good reasons to use STUDS and nuts............
    LOUD BOATS SAVE LIVES
    south,tx.
    I don't know if it was just the set i got or what but their was no torque ins with them.I got them from ARP's web site.I printed the page out and keep it in the shop.
    Mohave Valley/Quartzsite
    Hey moneypit, you ever try SWAK? That's what we use and works great!!
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
    [email protected]
    Ohio
    I've used pipe thread sealer for years on stock bolts with on problems. When I assembled this engine with ARP bolts, I used ARP thread sealer. No leaks in 5 years.
    Tim
    Default Lube/sealer?
    Tim
    Is their lube a sealer? Or a total different product, and does it reduce the required torque?..........What is Swak???? MP
    New Jersey
    El Monte
    Only on the Mark IV blocks. The Gen V & VI are blind holes and use lube only.
    Just FYI
    B & D Marine Performance
    El Monte, Ca.
    Bullhead city AZ
    sooooooooo..... Does anybody know what the torque specs are ???
    I cant seem to find em and they were not in with my bolts
    My bad, need to learn how to read. Those numbers are what I use for with studs.
    Special Thanks to:
    D21 ENT
    J.J. @ Beaver Fab
    Bullhead city AZ
    Quote Originally Posted by stix818 View Post
    2savage4you, you live in Bullhead?
    I've always used 70 ft/lbs with oil unless it's specified otherwise!!
    Yes i do..
    70 ft/lbs on the shorter bolts too....
    Thanks, this is a big help, i did torque to 80/85 tall and 60/65 short and i used Jegs thread sealer... But im gonna tear into it and check it out one last time..
    Thanks again
    Newton Ks.
    Quote Originally Posted by 2savage4you View Post
    Hmmm,. that's main bolts sized, got to dig more.
    Sorry.
    Last edited by SmokinLowriderSS; 08-20-2009 at 05:23 PM. Reason: OOps, wrong size.
    H.L. Mencken
    Well, according to ARP's website:
    1/2"-13TPI (thread per inch) bolts, 180,000 PSI tensile ("High Perf" series) 111 pounds w/ 30-wt oil. 88 pounds w/ ARP lube. 17,000 pounds preload
    1/2"-20TPI is 122 pounds and 95 pounds, oil and ARP lube. 19,100 pounds preload
    The "Pro series" are a 220,000PSI tesile fastener.
    same sizes and lubes respectively:
    1/2"-13TPI bolts - 138 pounds / 110 pounds 21,200 pounds preload
    1/2"-20TPI bolts - 152 pounds / 119 pounds 24,000 pounds preload
    Standard Chevy head bolts are 7/16", NOT 1/2"!!!!
    Absolutely do not use those specs on 7/16" BBC head bolts!!!
