boost vs static comp guide??
Results 1 to 14 of 17
    Default boost vs static comp guide??
    I dunno, say I'm 9 to 1 alum heads. 10 LBS? I know there are tons of variables, I'm just wondering what would be the limit of boost for something like I've got? Pump gas wise, For me that's 91 octaine. I'm kinda thinkin I only need 1 turbo, like 10 lbs. of boost?? I'm one lost mofo,.. seriously.
    I am going to suggest less boost may give you a better chance of not burning holes in the pistons with pump gas, but I don't know what type of turbo system you are going to come up with. Better plan on at least using an A/F meter to set it up if you can't afford dyno time.
    Cantard 71hallett's Avatar
    snow bank
    A little 106 mm 1.50 housing and 12-13lbs should work ok.
    Thanks guys. I was thinkin 10-15 lbs ish. There have been a couple of pretty good deals on some log/banks style deals latley in the spam section, just curious if that might work for me.
    Placentia, CA
    If you're serious, I have a complete Race Arrow setup with wastegates that will get you to 15+ easily.
    steveo143 AKA DiMarco 21 II
    9:1 compression,10lbs of boost, 91 octane will put holes in the pistons and ruin alot of parts. Go for it if you use good fuel, 100 octane or better.
    You could pull it off if you take some compression out of it, say 8:1
    I would use the RACEARROW set up over the Banks system. Just my opinon.
    Good Luck!
    Right now I'm broke, but I wouldn't mind seeing a pic or 2. I'm just thinking out loud, thought I'd start to keep an eye open for a deal.
    Senior Member KLINGER's Avatar
    redlands/ aha quin
    Quote Originally Posted by Boost Daddy View Post
    Good Luck!
    so what if a guy wanted to run 91 with stock compression and a banks twin turbo? is 5-6 lbs the limit? just wondering i just got a banks kit
    snow bank
    Good Luck!
    I have no idea on the arrow or banks stuff but we run 12-15 on pump all the time on blowthrough. 1000hp and change.
    Quote Originally Posted by KLINGER View Post
    8:1 compression you can safely run 10-12lbs on 91 octane.
    I've always been told alum. heads is like dropping a point in cr. Also does anybody have any idea how altitude will come into play I'm at 4500 ft, I've also been told that's like droping another point.
    You should be able to run a couple of pounds of boost more due to the elevation.
    Fresyes
    Hey-- Marvelous Marv! Thought that was you. Then I noticed your location. Good to see you here. Neil
    He knows his chit guys. I've known him for 25 years. Lots of time w/ Holley, and The Blower Shop and life long friends w/ Carson Brummet. Now doin' his own thing.
    He's shy, I'm not. Here's his site. http://www.boostdaddy.com/
    Is it just me or are toilet seats getting smaller?
    Default Shy?
    Quote Originally Posted by rightytighty View Post
    Oh yes, Marv has always been known as a very shy guy. He has been this way since he was very young. If you guys need some good info, just ask him and maybe we'll be able to pull him out of his shell.
    Good to see ya here marv.
