its running !!
Results 1 to 8 of 8
its running !!
    Jan 2013
    Default its running !!
    picked up 250 rpm with tunnel ram and vac pump on a A hi-helix impeller, now at 5700 rpm, now get impeller cut and get rpm up
Name:	eric 1 2014-04-13 001.jpg
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Nice work man
    QE 439 Twin Turbo
    Jan 2013
    thanks !
    Very nice!
    You know, I heard its going to use more gas. I don't know why, spinning an additional 250 RPM and obviously making more power to do it. But I 've been told it will. Brace yourself for it.
    Nice looking job!
    Close to the water...
    Quote Originally Posted by eric tx20 View Post
    What RPM range are you going for !
    Jan 2013
    max tq was at 5500 and max hp was 6500 with old intake and single carb so I think if I get it up to 6300 to 6500 I will take more advantage of the profiler t/r and then when I add fogger I will keep it under 7000
    Jan 2013
    Very nice!
    Nice looking job!
    dam, profiler should have put a warning label on it!! that's why its a pump gas motor, I knew I would always have my foot in it!
    Jan 2013
    I love the way my throttle linkage turned out, the top has holes taped for it and had to run cable to the back, the carbs sit on a 8.5 inch centers
Name:	eric 2 2014-04-12 001.jpg
