injection comparison
Results 1 to 14 of 21
    May 2012
    Default injection comparison
    is there any power to be had or lost between a hat injector(bug catcher) compared to the older style 4 hole vertical hilborn I just picked up a 6-71 littlefield and want to go injected alcohol on a 336ci sbc
    Dec 2010
    Sapulpa ok
    I would stick with the hat.
    May 2012
    Quote Originally Posted by piston in the wind View Post
    to keep the air speed up for the small cubic inch or is the hat just a better design I have he 4 hole already
    Members only MAXIMUS's Avatar
    Close by
    Quote Originally Posted by bowtiebro View Post
    The 4 hole upright is a pretty friendly set up from what I have seen. If you make sure it is set up for you application, it should work well. The Enderle's tend to be a little more touchy. Besides a Bug catcher is for lawn mowers... You must of ment a Bird? Buzzard is better...
    Sep 2010
    I have an old 4 port upright that I ran for a long time and can say that it can be set up to run good and be user friendly. The only reason that I took it off was everyone couldn't start the motor when I wanted to ski. I never even primed it to start. About the time that the oil pressure came up it had fuel. I did make a water pump that was mounted low in the boat and the fuel pump was on the back of it on the other side of the motor plate. You can't beat the throttle response ! :-) I am going to put them back on since I don't ski any more . :-(
    GD
    May 2012
    I meant bug its only 336ci
    May 2012
    The vertical 4 hole has a lot better throttle control.
    is that due to having the injector in the throttle bore instead of the open plenum?
    Yep, and the fact that the blades are smaller. Some hats like the Crower and Hilborn 4 hole have better control than the Enderle type hats as well.
    Between the size of the blade, and the lack of surrounding bore, it doesn't take much blade movement with a big and ugly to match the flow of a bug wide open.
    May 2012
    right on same kind of theory I had going in my head thanks for the insight now I just have to find a junk hood to cut a hole in for the scoop to peek out of
    Close by
    Ummmm..... actually I must disagree with you Bobby... This is not a carburator and we don't care about air signals to the horns... What I have seen is more due to barrel valve style, location of the bypass poppets and fuel pump size in relation to usage. Andy's set up worked like a charm right from Hillborn with their "shelf" tune. For a throw on deal the 4 hole hillborn is simple and works. For making lots of power the fuel distribution on that set up is similar to your idea of a rock and a hole. However... its a pretty good set up.
    I was not talking fuel control. Throttle control!!! Like in not needing some nautilus snail cam to doctor the throttle input from the right foot. Specially if you're an old worn out diaper wearing geriatric
    Jan 2011
    Mickleton, New Jersey
    the vertical 4 hole has a lot better throttle control.
    x 2
    I've driven both and owed both the more holes the better the handling and throttle responds
    Jan 2011
    Bug catcher is for a lawn mower. Tell Duff Daily that
