Bearing choice, rod's and main's
Results 1 to 14 of 25
    Default Bearing choice, rod's and main's
    Going thru my mill this winter, whats the preferred bearing these days for my 540 std deck motor. Thinking Clevite H series for both, pro's, con's, any suggestions welcomed.
    That is the standard. Unless you are crazy cruel on your bearings. Then you go V-bearings but they are tough to read and pretty much only good when your tune up is pretty much perfect. But if you are not top alcohol or fuel, just stick with the H series stuff.
    They should work fine. Just mkae sure your tolerances are right, and the finish on the crank is good. If you're worried, I think they have a coated version.
    I thinking no tighter than .0025 for rods and mains. Sound correct for jet boat duty?
    Newton Ks.
    perfect
    H.L. Mencken
    Lurker
    NC
    I would use .0025 as my low limit for the mains and .0025 for my high limit on the rods. Like to see the mains closer to .0028-.0030 and the rods at .0020-.0022 but that's just me!
    Are they that much better? what would be the plus to using them?
    #55
    Tri-Cities, TN
    In case something happens the coated stuff is ALOT less likely to weld itself to the crank. On a build I look at coated bearings as a $175 insurance policy.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    i run coated main clevites and they're worked great so far
    anybody ever use the king acueler(sp?) stuff? i hear good things on other boards bout em, never used a set personally.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    we have 3 sets of kings in 3 mills around here tom they seem to be holding up just fineall of the high performance kings not the stock replacement p series.
    we put them in gopher's 557bbf sanger sj and they've held up well, but its just a 11 to 1 na deal, no nitrous. they looked just like clevites, but a bit darker colored. just keep see'n alot of guys running them, most be pretty decent bearings.
    lake Ouachita AR
    well tom i have had a set in my mill for 2 years,run nos on my mill.you and me both now its not a big hp mill but it does take alot of abuse,lol!!!before that i had the same bearings king i ran for 3 years prior,they still looked good when i tore it apart would have re-used them but had a new set on the shelf.
    dads 505 has them also
    we have a 406 that has them.i think they are and i have always been able to get them cheaper.
    Why the split, on the rods and mains, what does the looser mains accomplish, vs tighter on the rods. Thanks for the input
    Sleek...take a second and picture what a crank is going through under power at the mains, and at the rods. Ideally, the smaller the clearances, the better.
