What do I need to swap in the BBC
Results 1 to 14 of 19
    Senior Member Notalent's Avatar
    Dallas/HB/LBC
    Default What do I need to swap in the BBC
    Before I get the engine in the works I want to make sure I have all my cookies in a jar. Help me compile a list of what I need so I can start ordering parts. a 650HP BBC Swap. 1971 Chevelle, built TH400 Trans, 12 Bolt with Posi and 3.55 gears, Lakewood lift bars, rear stabalizer so far I know I need this following, but having a brain fart
    *Already have solid Motor Mounts
    Torque Converter
    4 Core Radiator
    Twin Electric Fans
    Pulleys/Brackets
    Headers
    U-Joint upgrade
    New shocks and coil springs (need anyways)
    "Pain is a figment of your Imagination"
    what happened with the stroker sbc ?
    Dallas/HB/LBC
    NO REPLACEMENT FOR DISPLACEMENT
    We have the 502, but I want to R & D a new build to sell so were going to build a 505 or 510ci, 4340 forged bottom end, Profiler Heads, either a Sniper Intake or Edel Victor R manifold.
    Once its in im going to lay down some 1/8 and 1/4 mile numbers for the Team Chevelle website as well.
    Quote Originally Posted by Notalent View Post
    yes there is, we folks from okla. call it BOOST the bs'n we did awhile back when you 1st got the car put ideas in my head bout a big hp sbc, and my bigggg turbo for my sbc came in today
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    fuel pump , bigger lines, tranny cooler , I would upgrade the axles in that rearend , you will have to do some work to get it to hook up - those chevelles are chanllenging at times to bite . I would also stiffen up the chassis a lil so you don't pancake the car . To help us out - what are you going to use the car for ?
    Torque Converter
    4 Core Radiator
    Twin Electric Fans
    Pulleys/Brackets
    Headers
    U-Joint upgrade
    [/SIGPIC]
    did the 12bolt have c clips? if so, c clip eliminators
    Ukiah,Ca
    Don't forget your solid tranny mount - Or you will be very unhappy
    Torque Converter
    4 Core Radiator
    Twin Electric Fans
    Pulleys/Brackets
    Headers
    U-Joint upgrade
    [/SIGPIC]
    Dallas/HB/LBC
    Nice...that should be damn bitchen!!!! I want the sbc but this will kill a few birds with one stone...and I dont mind.
    It is going to be a Street Strip car. About 70% Street 30% strip. I havent checked to see if it was a C clip rear end or not...I was just gonna run it till she went and have Currie build me up a nice 9 inch. I will also be running some M/T Street Radials
    Southwest corner AR
    Torque Converter
    4 Core Radiator
    Twin Electric Fans
    Pulleys/Brackets
    Headers
    U-Joint upgrade
    Springs? What brand? I used Moroso Trick front and rear had good luck with them! It's a blast to drive out of the hole on one RR Tire! LOL! Rollcage will help the twist problem! 79 malibu 3300# car 1.24 60ft. times 6.30 118-122 MPH 1/8 mile all stock car! 468BBC 725-750hp, springs F/R and 8.5 456 10bolt rear no C clips and prayed it would holdup! Have Fun! WT
    WT
    WFL Crew!!!
    Woodstock, IL.
    Better brakes.
    Cantard 71hallett's Avatar
    snow bank
    The edelbrock bars seem to work alot better than the lakewood stuff.
    Cheap 50/50 shocks and a anti roll bar and your gona have no problems. Anti roll bar bit of a pain to put in one of those but work absolutly awesome. No more air bags which are just a bandaid anyways.
    Got a converter you would probably really like.
    Buy the motor mounts made by all star... much stonger than the pos moroso bent and splitting in half ones.
    ......It is going to be a Street Strip car. About 70% Street 30% strip. I havent checked to see if it was a C clip rear end or not...I was just gonna run it till she went and have Currie build me up a nice 9 inch.
    Bad idea man. When a c'clip rear end fails, the axle pulls out and bad things happen with the rear wheel. A Curry or Chassis works RE is the best idea, but if your out of $$$ at least upgrade the axles in the 12 bolt.
    Good luck
    Q.C./Big River
    NO REPLACEMENT FOR DISPLACEMENT.
    Sure there is, Nascar runs small blocks that are pushing 800 hp. Obviously you can get much more from a 502 but how much do you really need. You should be able to get what you want out of a small block.
    What Nascar motors lack in displacement they more than make up for in $$$. Cup motors are insanely expensive.
    We ran small blocks when we raced NHRA and it's pretty easy to build a 650+ HP SBC. However, the same $$ will easily get you 850+ in a BBC. In a heavy street car like a Chevelle, a BBC is the only way to go. Been there, done that.
