Problem
Results 1 to 14 of 15
Problem
    Bullhead city AZ
    Default Problem
    I installed ARP headbolts and now my Bassets wont fit , the bolts hit the flange. So should i grind the flange or is this a common problem with another way to fix it
    I'm famous ! Lucky's Avatar
    Ukiah,Ca
    I had the same problem with my lightings - I did grind off the head - What i found after is wasn't as clean looking - Why not take the head bolts out and trim / tap so your still clean looking
    [/SIGPIC]
    Bullhead city AZ
    Well if i grind it you wont be able to see it , its on the bottom.
    I just dont want to F-Up anything and make it weak
    TJS
    TJS is offline
    CT
    I use head studs and had the same problem. I notched them all uniformly on a mill and touched them up with Eastwood Exh coating.
    T.J.
    Bullhead city AZ
    Sooooo..... grind the bolts ??? or the flange
    Bullhead city AZ
    THE FLANGE
    Thank you
    DAMN, were you standing there with the grinder in your hand watching the puter monitor? fastest response ever
    Lurker
    NC
    THE FLANGE
    Thank you!!!
    As I was reading this thread I was starting to get worried!!
    Cantard 71hallett's Avatar
    snow bank
    I have also found that you dont normaly have to grind the whole flange.... just clearance the back side and the front (side you see) looks untouched.
    Quote Originally Posted by 468Bahner View Post
    You knew the correct answer all along
    #55
    Senior Member LicktySplitJr's Avatar
    I had to do the same thing with mine, just small notches where the flange hits the bolts and your good to go......Oh and GRIND THE FLANGE
    I too had issues with mine not clearing ARP headbolts and had to grind some off the flange.
    Then someone told me if you take the washers off of the outside head bolts they'll clear just fine. Not sure if this is considered recommended practice...maybe someone else can post up on their thoughts regarding removing the washers from the head bolts.
    Newton Ks.
    Iron, fine.
    Aluminum, not so much, NO.
    H.L. Mencken
