drill size
Results 1 to 14 of 29
drill size
    Arrow drill size
    What size drill bit is need for a 18mm 1.5 tap (02 senor).
    Lost Wages, NV
    http://www.korit.com/tapndrill.htm
    Says 16.8mm drill...next smaller fractional would be 21/32, at about .050" smaller. That would work though.
    Keith-
    Colfax, Ca
    Quote Originally Posted by STV_Keith View Post
    I think you mean .005" smaller. (.050 would be a lot to take out with a tap.)
    Lost Wages, NV
    No, the 21/32 is .050 smaller than the 16.8mm prescribed to drill with. It's the next smallest fractional size listed, and I'd imagine, easier to find than 16.8mm.
    Keith-
    if that the case, 11/16 would work better because it's .03125 larger than 21/32 therefore making it only .01875 smaller
    someofamitch
    Draper, Utah
    i have to go with steel on this one.
    16.8 mm = .661 inches
    21/32 = .656 inches
    difference = .005 inches.
    James
    Senior Member superdave013's Avatar
    75% thread engagemant would be a 0.6511" hole. Use a 21/64 drill (0.6562")
    To get wizzy the spec for a class 6H is:
    minor diameter should be 0.6447" ~ 0.6565" <- 0.6506" is what the hole really should be
    pitch dia 0.6703 ~ 0.6778"
    major diameter 0.7087"
    Thread height 0.0320"
    Flats on top of thread 0.0148"
    someofamitch
    Draper, Utah
    Quote Originally Posted by superdave013 View Post
    you win.
    21/64 drill, eh?
    Easy enough formula is to subtract the thread pitch from the thread dia. and that's a good drill size. 18mm wiith a thread pitch of 1.5mm...18 -1.5 would be 16.5mm drill. (16.5mm=.6496...closer to the 75% than 16.8mm which = .6614)
    if that's the case, 11/16 would work better because it's .03125 larger than 21/32 therefore making it only .01875 smaller
    Guess this is one of those cases where zero really doesn't mean zero.
    .50, .050, .005, are different, who da thunk it
    what about a class 3b fit? You know, like all the hose fittings in your boat should be.
    You crazy kids all argueing about a tap drill size.
