Dual Keyways
Results 1 to 14 of 24
Dual Keyways
    Default Dual Keyways
    Should I cut dual keyways in my crank?
    1053 steel 4.00 stroke with a M3 Procharger
    I know it wont have the load that a roots type blower would have
    so whats the most common configuration? 3/16 and 1/4 @ 180°?
    I plan on running an ATI balancer/damper
    #55
    Kingman/Golden Vly, Az
    i say yes most definetly...i would use 1/4", full length slot & square allen stock for the key ...this is what i ran on my blown SBC ages ago lol...just my .02 cents
    FastRat
    Default Dual Keyway
    It is not needed on a BBC, except in the most extreme cases. The SBC has a problem with balancers lasting. Adding another keyway helps, but doesn't address the problem. There is very little material from the corner of the keyway to the seal surface. This is where they break. ATI offers 2 different hubs for their balancers. The first one adds 35% more material from the corner of the keyway to the seal surface. This will work with a stock timing cover and only requires a special seal. The second one adds 225% more material. It now has a BBC o.d. This requires a special timing cover for the SBC because it now has a BBC seal. It is pretty stout.
    yes BBC, so I dont need to worry about cutting the second keyway?
    #55
    You can go with a single 1/4" keyway and be safe. It's a PITA to have two keyways line up perfectly. A lot easier for a machinist to broach a new one in 1/4 and be done w/ it.
    I just got a reply from ATI, they suggested thier part # 917740
    it has a 3/16 keyway in the stock location and a 1/4 @180°
    they can also drill it for 6 pulley mounting holes on a 3.200 bolt circle.
    my machine shop said no problem cutting the second keyway.
    Procharger suggested a second keyway over 10 psi boost
    I'm setup for 8
    I thought the 6 bolt circle would be a good idea since I will be running a
    crank trigger wheel between the balancer and blower pulley.
    is this overkill? good insurance? or a waste of time?
    #55
    I'm setup for 8
    For the small amount it costs to have the 2nd key at 180 degrees, don't even give it a 2nd thought, do it and have the piece of mind. A decent machinist can get it right. My engine balancer does them for me, never had a problem with one lining up.
    The 6 bolt balancer is also the way to go.
    Senior Member The Violater's Avatar
    I'm setup for 8
    Thats the balancer I bought, came with 2 slots had the crank done, end of story, not absolutely nesc, but why not????
    / The Few The Proud TheBlown
    "It's HONDO, honey" Kyle's Avatar
    AZ, Queen Creek
    Thumbs up
    cheap insurance for gulling up the end of a perfectly fine crank and then tearing it ALL down, mine cost 200 and bergeron cut the dampner as well
    ___________________________________________
    ___________
    "Chine walkin: (verb) - to show another brother that you will stay in to win. (syn.) Holy *hit!!!!!! Don't Lift!!!!!"
    Won't argue with that....
    ...or that.
    AZ, Queen Creek
    ...or that.
    This guy
    Get the key way cut Outlaw
    ___________
    Thanks for the confirmation, It will be done....
    #55
    AZ, Queen Creek
    K you got me..... wanted to up my post #, did it again
    ___________
    LOL
    #55
