seal adp.
Results 1 to 14 of 17
seal adp.
    MD
    Default seal adp.
    I have a BB-Chevy rear seal adapter and on the outer side there is a lip on 1 edge does that lip go to the inside or outside of the block?
    im thinking it go's in but the shop put it out
    BB Chevy Rear Seal Adapter Gen V VI Block BBC 1 to 2 Rear Seal 7035 7036 | eBay
    MD
    128 view's
    i can't believe im the only one using one of these
    im thinking the lip go's inside
    I don't think it will even fit correctly with the lip inside. There is no place for the lip to seat into.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Post up a pic. Are you putting a 2 piece seal crank in a 1 piece seal block?
    Didnt see the link the first time. I have used them and dont remember. Call Chris Straub. he sells them for B&B
    QE 439 Twin Turbo
    I think you need to actually look at the block and the answer should be obvious. If the "lip" is about .030" it fits to the inside and will hold the thing square, as there is a tiny groove in the block and cap.
    I re-read your post, apparently a shop put it together. I actually went out and looked at a Gen 6 block that I have here to determine that there is a small groove inside the original rear main seal surface where the seal adapter goes prior to my first reply.
    MD
    I just had the machine shop build my short block and when I install the crank bolts they hit the adp.
    same everything
    MD
    yes a 2pc seal in a 1pc block gen5
    the motor is at the shop and im going there in the am
    I think it was in be for and all worked fine now the bolts hit
    The step goes to the inside. It helps lock the adapter in place.
    MD
    im going there in the am and have them flip it then all should work fine again
    Is this true for the 5 and 6 blocks both?
    Stefs makes 2 different adaptors for the 2 blocks.I know its not a Stefs, but do both Stefs adaptors have the lip? Is there a place for the lip in a 5 block?
    Not sure about that. This is a Gen6 block. You can see the groove:
    If the OP had the adapter in the block before, then I'd say it's in backwards now.
    That's why I was questioning. The groove seems to be self explanatory.
    I have always wondered the difference between the 5 and 6 Stefs adaptors.
    There is also a groove in the main saddle and with what appears to be a threaded hole. #4 saddle appears to have 2. WTF
    New Port Richey, FL
    There you have it again. It goes to the inside.
    I don't recall the B&B having a lip.
    QE 439 Twin Turbo
