Straub Engineering/Foxwell Motorsports
Results 1 to 14 of 18
    Chantilly Va.
    Default Straub Engineering/Foxwell Motorsports
    Chris and Scott, this winter did a "Top End Package" for my 540. We spoke many times prior to, and during the build. Scott bought a set of 305 AFR's, did his magic. Chris designed a solid roller that brought this package to life. They came up with an estimated power for my 540 pump-gas lake-motor build at 809 H.P. @ 6200 RPM. I am pleased to report that last weekend, I put the boat in the water and recorded , according to my EGT Sensor, max RPM, 6160 RPM. The Hi Helix impeller chart says my engine is making about 811 H.P. They missed this one by 2 H.P. Gotta give it to these guys!!!!!! Thank You Chris and Scott.
    Jun 2010
    Its a hell of team. Scott buffs & fluffs the ports, and gets Chris to make his stuff look good with some fancy dart board he uses to select cam profiles.
    Mar 2010
    Clarksville, TN
    Sweet !!!!! That outta make that winger fly
    Bad dog, no biscuit. Don't be giving our secret away.
    Quote Originally Posted by sunkisst View Post
    Jack, thanks for letting us be a part of your project. Always enjoyed talking with you and glad to see your project finally come together.
    MD
    A better mouse trap
    Senior Member CNC BLOCKS's Avatar
    Sep 2009
    Very nice!
    Douglas, MA
    Awesome! My package should be in soon...can't wait!
    Chantilly Va.
    And, I might add, this was done with one carburetor !!!
    Tri-Cities, TN
    Jack,
    Thank you for the opportunity to work with you and thank you Mr. Estep for you last project also and the return business. We are getting quite a bit of return business these days and that tells me our customer satisfaction is very good.
    Chris
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    Tri-Cities, TN
    Your stuff is in the "work area".
    Chris Straub
    Straub Technologies
    Douglas, MA
    Pics!
    Aug 2012
    Nice! This is almost the exact motor I want to build! Which hi helix impeller are you using?
