Pulstar Spark Plug
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 45
Pulstar Spark Plug
    Atlantic Beach, FL
    Default Pulstar Spark Plug
    The latest "miracle" in technology. On the other hand, if they're right... Thoughts?
    Anytime you put new plugs in your engine it's likely to run a bit better and get better mileage. You can send all the voltage in the world to jump that spark plug gap, but in the end, it only takes as much energy as is needed. Marketing hype IMO.
    A lot of the E 85 conversion kits suggest running these plugs, to help with cold starts.
    TEN THIRTY ONE RCB19's Avatar
    At 25 bucks a piece I think I would look into a proven ignition system.
    RCB
    Quote Originally Posted by RCB19 View Post
    Bingo. In essence, all they're doing is upping the ignition system's capacity. The thing is, it only takes enough energy to jump the gap to overcome the resistance. Just because you have a 40K volt ignition system doesn't mean it's going to have a 40K volt spark. It may only take 10% of that current to pass through the resistance at the electrode. More fuel (boost or higher compression) or more difficult fuel to ignite, like alky, means more resistance and more current required to spark. Most modern ignition systems have plenty of energy and like Ross said, I'd be upgrading my ignition before I spent 25$ on a new plug. Hell, the factory replacement plugs in my new Mustang were $12 ea!
    Cantard 71hallett's Avatar
    snow bank
    If it isnt broke.....
    Newton Ks.
    Marketing hype IMO.
    Mine too.
    H.L. Mencken
    Bill, only because I like you, I am going to tell you the path to quicker lap times...........get a heavier right shoe and remove the "chicken lever from your boat! It's not in plugs, float needles, miracle snake oils, voodoo, etc etc. It's this simple, floor the sum bitch and turn left when you get to the turn bouy!
    Any one who doesn't fully understand exactly what Steel posted, really owes it to themselves to read this book, by Dr. Jacobs, and you'll find out how little you really know about ignitions. Bottom line, the coil will only unload as much voltage as it takes to jump the gap and no more. Until you get into plasma technology like F-1, which requires bazillion $ plugs just to survive, all the voltage in the world is of no help once the gap is jumped. Now how long the spark lasts is another topic, but these POS's add nothing to the duration of the spark. Also, you ALL are aware of the fact that Split Fire had there asses sued off and had to stop their BS adds.
    Spiral out MikeF's Avatar
    gn7 is most correct on both posts!
    Any one who doesn't fully understand exactly what Steel posted, really owes it to themselves to read this book, by Dr. Jacobs, and you'll find out how little you really know about ignitions. Bottom line, the coil will only unload as much voltage as it takes to jump the gap and no more. Until you get into plasma technology like F-1, which requires bazillion $ plugs just to survive, all the voltage in the world is of help once the gap is jumped. Now how long the spark lasts is another topic, but these POS's add nothing to the duration of the spark. Also, you ALL are aware of the fact that Split Fire had there asses sued off and had to stop their BS adds.
    Thanks for putting it in more simple terms.
    snow bank
    Maybe these could be used as piston savers.
    Nawww....they would ignite the mixture even quicker....leading to more holes in more pistons.
    A set of these and a turbonator would definately put you in the 7 second zone..........naught! MORE SNAKEOIL
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
