Burst panels
Results 1 to 14 of 18
Burst panels
    Default Burst panels
    I'm in the process of building my first blown alcohol motor for our 8 second bracket boat. The blower combo came of a similar application to ours; a 555 BBC with a 8-71 blower. Although the manifold has space for one, it doesn't have a burst panel or other pressure relief. The guy I got the stuff from said he got away without one, but thought it best I add one. So, is a burst panel necessary. I've also seen the spring loaded pressure relief style as well. Is one style preferable over another.
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    I would definitely install a burst panel, David. It's cheap peace-of-mind in case the blower backfires. Some guys will tell you it's overkill unless you're running Top Alcohol, but I'd rather spend a hundred bucks or so and save my $2k blower. I think the blower companies charge $150-$200 to machine the intakes for the burst panels. We did our own machining, so we only have the cost of the cage, the hardware, and the panel invested in our setup.
    Adam
    Hallett 210
    So Cal
    David ... go with the burst panel style ... not the spring type. Spring type is more of an old school street application, burst panels are much more reliable and will go when they are supposed to.
    Brian
    I've always been curious why a blower could go kaboom? Too lean?? To much timing? What is blower backfire and what causes it? Sorry for the tj.
    got a question for you guys while this subject is up. i'm building 2 blow thru turbo deals over the winter, 1 twin turbo 496, 1 big single turbo 383. i've been thinking bout burst panels, but i was wondering if the old spring type could be put on the single plate intake. both motors will see 25psi, both will be intercooled alot, but backfires happen. you guys think the lil spring type would do? most guys just blow to shit their lil carb bonnetts that cost 200bucks i was thinking there's a better way
    i know where your mind's goin
    spokane, WA
    Turbo guys run BOV'S(blow off valves) no need for a burst pannel. A single 50mm BOV will be just fine for both applications.
    Travis
    Default Bov
    Here is a link to some blow off valves.
    [URL="http://www.racinglab.com/blowoffvalves.html"]
    Default Burst Panel
    Wet-N-Wild is correct! They are cheap insurance should you ever have an engine backfire.
    Cantard 71hallett's Avatar
    snow bank
    I think your talking about the fab ones not the cast ones, If you explode one of those cast ones I will shake your hand lol
    I do agree with you on the fab ones..... always seem to blow apart at the weld...... I was looking at one a while ago and seems that they were just butted together and welded aka melted together to look pretty instead of leaving a small gap between the pieces and then doing a solid weld.
    my .02
    Paul
    Quote Originally Posted by TwinTurbo540 View Post
    Travis
    yeah, i'm with ya on the bov, but what about under the carb? something to protect intake gaskets
    my .02
    Paul
    ev hat is 3 pieces, the guy i got my turbo from has 1 sitting in his shop, sent me pics, its ugly
    So Cal
    It's usually a lean out condition in combination with the advanced timing.
    If it goes too lean ... boom.
    Quote Originally Posted by Wet-n-Wild View Post
    Thanks Adam, kinda what I thought. We can do the machining ourselves so that's not a deal. Saw your pic in one of the drag rags. Kinda fun to fly them like that!! .
    Quote Originally Posted by BUSBY View Post
    Brian
    Yea, gonna call Good Vibrations and pick up some misc stuff. Will throw the burst panel and hardware on the list.
    .....If it goes too lean ... boom.
    We've done the "boom" thing. done with that
    Thanks all
