Mag service
Results 1 to 8 of 8
Mag service
    Senior Member snake321's Avatar
    Middletown, Connecticut, United States
    Default Mag service
    Am I supposed to send a mag out for servicing????I just got a ronco vertex mag at the swap meet and it's been on the shelf for awhile. If it's yes, who do I send it to?
    YOU LIE!!!!!!!!!!!
    Quote Originally Posted by Ultra26 # 1 View Post
    I've been known to be a jackass a time or two.
    El Cajon, CA.
    You should see a good spark at the points when the gear is turned by hand and you can put a plug in one of the plug wires and ground the plug's threads to the mag body and turn the mags gear to check for the spark at the plug.
    Joe Hunt Magneto's, Magsarus, are a couple of the rebuilders.
    adjones419 Wet-n-Wild's Avatar
    Shiloh, IL
    Spud Miller at Fuel Injection Enterprises is great with Mallory and Vertex mags.
    Adam
    Hallett 210
    RAT PATROL rich s's Avatar
    S central Pa.
    Thumbs up
    Quote Originally Posted by Wet-n-Wild View Post
    i 2nd
    Shiloh, IL
    Quote Originally Posted by rich s View Post
    i 2nd
    what adam said
    He's also a super nice guy who is easy to talk to.
    Adam
    Hallett 210
    Thanks guys. I got the mag for $45 at the swap meet from some kid that said it was his dads. I'll send it out to this guy.....
    YOU LIE!!!!!!!!!!!
    Default Try if first.....
    While sending them to a rebuilder isn't a bad idea, mags tend to be pretty bullet proof. Pull the cap and hold the wire that goes up into the cap about 3/4" away from some grounded metal. Turn the distributor gear by hand and see if it arcs.... If it does, stick it in an engine and see how it does. Do not touch either the ground lug on the side or the wire out of the top, it will shock the chit out of you. Done that!!..
    I ran a mag on a shovelhead years ago and learned the shock trick. I tell people to hold the springs so they don't shoot out....
    YOU LIE!!!!!!!!!!!
