Oil Pans
Results 1 to 14 of 17
Oil Pans
    Cantard 71hallett's Avatar
    snow bank
    Default Oil Pans
    I have not worked with a 502 block yet but looking into putting a 2 pc seal crank into one. I can get one from stef,s no problem but wondering more about the oil pan. How different are they or are they different. Have a bunch of parts around here I wouldnt mind useing up.
    Paul
    Paul
    Make smart remarks, then ask for advice. I see how you Kantards roll....
    Can't answer your question. Don't know.
    snow bank
    Fine..... I hope your head gaskets leak like a lawn sprinkler. lol
    Ooohhhh...ouch!
    Still can't help ya...really don't know. Is this a Gen5 block?
    snow bank
    Ooohhhh...ouch!
    Was told it was, going to get the #,s off it tomorrow.
    Paul
    You are looking into putting a 2pc seal crank into a 1pc seal 502 block?
    The pan for a 1pc seal is significantly different.
    You still need the gen V/VI oil pan, the radius is huge.
    Tri-Cities, TN
    A gen 5/6 seal radius is different, the length of the pan is different the rail spacing is different. Other then that they are the SAME
    On a side note we are getting reponses back now from customers that have used the new Melling Billet Select oil pumps and it is all positive. No signs of cavitation in marine or circle track applications, no distortion in housing bores. Pump seems to be a hit.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
    snow bank
    Are they to different to be able to cut two and make one? Mate the gen 4 bottom to the gen 5/6 top? Or is this whole block idea a bad idea?
    Tri-Cities, TN
    I just went through this with a board member that has a Stef's pan and is changing blocks. To cut the pan and lengthen it for the Gen 5/6 and then cut the seal radius out and the rails would be not be cost effective and if you did it once you got done it would look like you cut up a pan even with our welders work. Jus not cost effective.
    Chris Straub
    Straub Technologies
    I wouldn't go there.
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    Obviously they are clearly different as the other board members have outlined above. Seems like a whole lotta work to cut them, as cstraub stated above it is simply just not cost effective and are you going to be getting the same quality as a new pan? Let me know if you need help getting one. I carry every major brand-Hardin Offshore, Hardin Jet pan/v-drive, Dan Olson, Keith Eickert, Dooley, I can make you a killer price for being a Perf. boats member and guarantee the lowest price anywhere. Thanks,
    Brian
    CP Performance
    www.cpperformance.com
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    snow bank
    The more I think about this the bigger the disaster I think it would be. Next is if I have to buy a pan for $1000 plus still do all the crap to the block I am prob most of the way to a dart. I wanted to put it out there in case I was missing something. The fabing the pan doesnt bother me I can do that here but this would probably turn into a dozen obstacles. Thanks for the info.
    Paul
    snow bank
    Ok, so I just went and picked up the block. Casting # is 10237300 so it looks to be a gen6. I set my oil pan on it and the bolt holes on the rails are the same width but the difference in about 1/2 inch in length. If I cant make a pan work I had better close shop. I would definitely be interested in a bullet hole pan if you have one as well as a timing cover so I could bolt everything together before I weld it so nothing moves on me. This can work I am no longer worried. Thanks for the replies guys!!!
    Paul
