Electric fuel pump mounts
Results 1 to 14 of 21
    Anaheim Hills
    Default Electric fuel pump mounts
    Going to an electric pump. Im looking for some ideas of where to mount it. What did you fellas do?
    I've got electric "pusher" pumps that feed the Merc mech set up. Mine are mounted low on the srtinger to help them draw fuel up from the tanks.
    Darrell.
    San Diego.
    28ft Sportcat
    With Twins
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    Bouncing off rocks TryMe's Avatar
    Sep 2008
    St Louis
    Bigamist - thats a nice setup, where did you get that?
    I would send you a pic, but I cant get my camera inside my fuel tank
    #55
    Senior Member cruzer's Avatar
    Chandler, Az
    Best place is dependant on where your fuel tank(s) are. I have gunnel mounted fuel tanks in my boat with a tank selector switch. I mounted my fuel pump low, behind the rear motor plate near the jet intake. My pump will not prime from either tank, even when the tanks are full. Once the pump is primed however, this works just fine.
    I am thinlking about dumping the selector switch, buying another check valve and pump and mounting the pumps low and as close to the tanks as possible. Maybe this will help with the priming issue. My only other choice is to buy 2 submersible pumps and put them inside the tanks themselves.
    Cruzer
    21 Eliminator Daytona. Blown 540
    S.F.V.
    Quote Originally Posted by TryMe View Post
    It's from cpperformance, there are some nice billet ones out there also....but i can't find the website.
    Quote Originally Posted by cruzer View Post
    Thats what I did, I used the Aeromotive A1000, I haven't tested it yet
    but according to Aeromotive it will work better in the tank than out.
    I have a 100 micron filter a A1000 pump and a check in each tank
    and my tank selector switches the return fuel and power to the fuel pump
    relays
    #55
    MI
    Mines mounted on the stringer.
    Anaheim Hills
    Are you guys sucking from both tanks at once or using a selector vavle?
    MI
    I'm pulling from both tanks.
    Senior Member 4CE FED's Avatar
    Im running a bypass style system with the A1000 and bypass regulator. I am drawing off boat tanks at once, return line goes back to separator. Works perfectly. I do have a manual tank switch valve, but never use it.
    I just bought another motor mount, drilled and tapped the motor on, and used longer bolts through the stringer so I didn't have to alter the boat.
    Might be overkill, but the pump is heavy and don't want it coming loose/leaking fuel
    Atlantic Beach, FL
    Is it too late to talk you out of it?
    Anaheim Hills
    Quote Originally Posted by 4CE FED View Post
    Very cool set up.
    Thanks to everyone for sharing. Im getting some great ideas.
