Balance question
Results 1 to 11 of 11
Balance question
    Bullhead city AZ
    Default Balance question
    If you have ran your engine with a flywheel for years and need to change it over to a flexplate , will this change have a big affect on the engine ?
    Cantard 71hallett's Avatar
    snow bank
    Not if you keep it the same type. (int/ext)
    Kingman/Golden Vly, Az
    Quote Originally Posted by 468Bahner View Post
    i'm really not sure about the big effect, but, it sure will save a bunch of weight , thus, its gotta help some!
    FastRat
    Is or was the motor balanced? If so, internal or external? M
    MI
    I need to do the opposite. Flexplate to a flywheel. External balanced.
    Be sure you know if the engine is external balanced or internal balanced. Then replace parts accordingly.
    Bullhead city AZ
    Sooooooo.................. Yes or no..... changing the flywheel to a flexplate won't affect the engine.
    Its ext balance.
    This is my problem, I originally set up the boat with a BBC 454 with a flexplate... Now i bought Beerjets engine and it came with a flywheel.
    Now the engine needs to be moved forward about a 1/2" to make up the diff and need to buy longer bolts to install, PTO and flywheel..
    Or i just buy another flexplate and put everything together
    I just want to make sure im not going to hurt this engine
    [email protected]
    Ohio
    Put an external balance flexplate on and you'll be fine.
    Tim
    Its ext balance.
    Take the balance card and the old flywheel with the new flex plate or vise versa to a decent machine shop that does balancing and if he knows what he is doing should be able to figure it out. External balance is putting everything in-balance on the ends of the crank that is not in-balance inside the motor. Factory uses a scale of in balance and not. That would be why you have weights on the balancer and the flywheel/flexplate. A good balancer will get balance within 1/4 gram, inside or out. I would try to get as close to the balance card as possible.
    2sav...you kinda have to have an engine for it to affect in the first place
    Bullhead city AZ
    Well down here in Bullhead city we call this a engine... Now you boys in Cali might call it something else
